Results 1 to 10 of 24
Thread: Thermostat replacement
    Regular Member ChrisB's Avatar
    Nov 2007
    Bristol
    Question Thermostat replacement
    Has anyone replaced a thermostat on a 1.9 cdti 150 engine,looks like it's on the right hand side of the engine,an aluminium one piece cast unit with the temp sender on top.just wondered if it's a lunchtime job to do in the workshop?How much are they. Thanks
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Interesting - i was looking to do the same thing today and thats the only place where i could see the stat being
    Reckon there're gonna be around the £25 mark cause that's what one for my old 2.2 was,may even have to have the housing on this one aswell
    Will pop in to the Stealers on Sat to find out although i shouldn't think they will have a clue....
    Feb 2006
    Guttedsville
    Cost of the parts is around £31. The Housing and thermostat are one piece, held in with two or three torx style bolts. The housing lives at the top right hand corner of the head, just below what looks like some sort of fuel pump.
    Should take about 45 minutes or thereabouts.
    Nov 2007
    Bristol
    Thanks for that chaps...................looks likea lunchtime job then.
    Cheers..........Chrisb
    Nov 2005
    Somewhere in time
    Just picked mine up from the Stealers.....comes inside housing and also with a new sender unit as well but for £41 i'm glad it's not just the stat on it's own
    Nov 2007
    Bristol
    Got mine as well today through the trade at £35,will be fitting it saturday
    Nov 2007
    Bristol
    Job done,took me about an hour this morning at home in between showers.Now running at a constant temperature around 85 with a nice warm cabin.Thanks for your help guys.
    Nov 2005
    Somewhere in time
    Yep....done mine yesterday and i'm now running bang on 85 with out the temp dropping back down so a job well done
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    I don't suppose antone has the part number for the stat and housing complete so I can see if I can get it from Autovaux. Thanks.
    ireland
    hi all,this is my first post so be kind.i got my new thermostat from the stealers,attempted to fit today,what a fker of a job had to admit defeat so here to ask for advice,its the 1.9 cdti 120 engine ,right here goes,removed all relevant pipework etc even took battery and tray out,took out top bolt,lovey went to remove the bottom one theres a braket in front of it,loosend all i could find in the hope to move the what i think is a heat exchanger out my way to no avail,so how the fk do i remove the bottom bolt,had to reasemble with the old bstard back in any help woul be appreciated
  1. Thermostat Replacement - Any Tips?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2014, 23:30
  2. 1.9cdti 150 thermostat replacement
    By scotstrucker in forum Engine & Drivetrain
    Last Post: 5th June 2012, 20:01
  3. Thermostat Replacement
    By dexter69 in forum West Scotland
    Last Post: 18th May 2012, 18:59
  4. thermostat replacement
    By duncmill in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2010, 21:25
  5. vectra 1.9 120 thermostat replacement
    By tom_nw in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd December 2010, 14:41
vectra thermostat replacement
