Thread: annoying rattle noise
    Regular Member arniedavo's Avatar
    merseyside
    Unhappy annoying rattle noise
    alright folks
    as thread says ive got or my vectra 2.2dti sri has got an annoying rattle witch seems to be coming from the silver strip along front of dash (its coming from here because if i put a bit weight on it with finger it stops ?)
    ITS DOING MY SWEED IN
    does any1 no how to get to the back of this strip or how to remove so i can check it out ?
    HAS ANY1 HAD SAME PROBLEM ??
    THANKS IN ADVANCE FOR ANY ADVISE
    [Ex]Admin Duncan's Avatar
    Just get your finger under the edges of the trim and pull - fairly hard - it's only held on by spring clip things, Could be one of them is a bit loose/broken.
    merseyside
    would n`t like to break it ?
    do they come of easy enough and go back on easy
    luton
    i had mine off last weekend, all i did was open my glove box and gave it a pull from underneath and it came off pretty easy. dont go to mad and should be fine.
    merseyside
    cheers for that i`ll try tmoz fingers crossed
    wot they held on with ?
    Feb 2006
    Dorset
    just put some felt peices on the back of it , in places where its likely to be in contact with the rest of the dash, should cure it mine started doing the same to the point i pulled it off and chucked it in the back as i was on a motorway radio off and t'was driving i up the wall
    Quote Originally Posted by arniedavo View Post
    ..............it's only held on by spring clip things, Could be one of them is a bit loose/broken.
  1. Annoying Rattle - help!
    By Davies20 in forum Bodywork & Interior
    Last Post: 3rd May 2010, 11:55
  2. Annoying rattle
    By ironstone in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2010, 14:13
  3. really annoying rattle
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2008, 18:57
  4. Annoying Rattle
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2007, 08:02
  5. Annoying Rattle
    By ANDY GSI in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2007, 18:04
