Thread: Vectra Sill Kick plates - is there a better means of fixing to the sill?
    Default Vectra Sill Kick plates - is there a better means of fixing to the sill?
    Just bought the above off ebay (well identical ones to these off the same seller)
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...QQcmdZViewItem
    Although the quality is very good, I feel they're let down by the measly fixing strips provided. On the shorter ones for the rear, there are 2 short foam strips of double sided tape (one each end); and on the longer front ones, 4 double sided foam strips of double sided tape (one at each end, and another approx 10 cm in from the outer strip). The tape is no longer than 10 mm wide, and rather than running the full length of the sill plate, the tape is stuck on width ways and is no longer than 5 cm.
    Will this be suficient enough to hold them to the sills, or should I peal off the effort the seller has stuck on and use something else?
    When I tried a dry fit earlier, I found that they were slightly proud of the sills because of the 3M foam strips. Would something like impact adhesive / silicone rubber / longer 3M foam strips / or plain old double sided tape be better to stick them on with?
    Thanks.
    Regular Member cameraman's Avatar
    Leicester
    The VX ones I got had very strong "double sided tape" along the entire length. Had the same ones on my old car & they proved impossible to remove.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi m8 if you go to a motor factors near you they sell them in a packet for about 80p then you can make the strips aslong as you want them
    Quote Originally Posted by glynn View Post
    Is that for 3M foam strips, or double sided tape?
    they are foam strips not shaw how they are made by
    Thanks all. I'll try and pop down to my local factors tomorrow.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    my cill plate's are stuck on with the small pad's and they are going nowhere mate
    Midlands Mod Shop - NFFC.
    Here, there and every where!
    Go for the "No more nails pads" m8. They do several types including permanent fix. Pads
    or Roll
    B&Q etc stock them
    Regular Member rob888's Avatar
    Oct 2007
    lincs
    my sill plates are stuck on with double sided strips, not going anywhere
    Bought some double sided foam tape at the weekend. £3 for a 3 or 5 metre roll (I think that's what the man behind the counter said was on a roll). Gonna fit length ways. Gotta be better than the measy strips that came with it that are fixed as I described in my first post.
  1. vectra kick plates/sill guards....
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 18:05
  2. Last Pair of Kick/Sill Plates. VECTRA. *XMAS PRESSIE*
    Last Post: 26th November 2009, 19:54
  3. Kick Plates/Sill Plates-Stainless Steel-read "VECTRA"
    Last Post: 19th November 2009, 09:46
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
  5. Sill Kick Plates are on
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2009, 18:10
