Help!
Over then weekend and during this week i have notice that my traction control is working ,the traction control light doesnt even flash when the wheel spins. I have a 2.2 sri any ideas?
Help!
Maybe the bulb in the dashboard is not working?
Could be the fuse? If its blown then no TC. Light will not flash as system is not active.
As Guyver1 said,
I occasionally get problems with the traction control system, when its not working the warning triangle is lit on the display. If the system is working correctly the triangle comes on on start up and goes out as part of the start-up check process - it stays lit if there is a fault.
If I switch off the ignition a couple of times (and wait for 30 secs) it goes back to normal
