Thread: Headlight/Door warning buzzer
    Nov 2007
    Salisbury
    Default Headlight/Door warning buzzer
    Howdie,
    Got a small problem with the buzzer which sounds when the doors or lights are open/on when the keys out of the ignition. Everything works when the passenger door is opened, but nothing when the the drivers door is opened.
    Not being technical minded, not too sure where to start!! Any ideas?
    Rgds
    Aidi
    [Ex]Admin Duncan's Avatar
    What are you saying? The buzzer goes if you've got the lights on and open the driver's door? If so, that's normal - warns you that you've got the lights on when you leave the car so you don't leave them on.
    Mileage : 000
    No Duncan what he is saying ids that it buzz,s when the passenger door is open but not the drivers door as it should do, I was not aware that it buzzed when the passenger door was open?
    Full Member Big Sig's Avatar
    Sounds like somehow the passenger and drivers door open signal has swapped sides? No idea how!
    Quote Originally Posted by ed taylor View Post
    Ah right, I wasn't entirely clear what he meant.
    ...I was not aware that it buzzed when the passenger door was open?
    No, it doesn't. If it's doing what you say then it's certain;y not right.
    Have you had any modules replaced on the car recently for any reason? I wonder if they haven't been programmed from LHD mode (often the default) and it now thinks the passenger door is the driver's door.
    Nov 2007
    Salisbury
    Its a bit of a funny one this. When i test drove it, the buzzer was working on the drivers door the way it should. It was then "Network Q'd". The only other think i know they did to it was reprogram the spare key with thier plug in device (tech2 from what i have read) which got the key working.
    If it worked correctly when i did the test, and now its swapped, is something they can do with their plug in box of tricks?
    Rgds
    Aidi
    Mileage : 000
    I wonder if it can be "adjusted" to either right or left hand drive motors?? Via the Tech 2 then.
    Quote Originally Posted by akulla View Post
    Rgds
    Aidi
    I wonder if ity can be "adjusted" to either right or left hand drive motors?? Via the Tech 2 then.
    Yep, sounds like a monkey with the tech 2 touched something he knew nothing about......
    Rgds
    Aidi
    It sounds like they've somehow managed to alter the CIM module (module in the steering column that makes the pinging noise and integrates with the ignition switch - amongst other things) to make it think it's LHD.
  1. Lights on/Doors open/ warning buzzer
    By Rob1966 in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2012, 18:43
  2. Seatbelt warning buzzer
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2012, 14:06
  3. seat belt warning buzzer
    By mabski in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 10:40
  4. deactivate the warning buzzer on vectra C
    By mustangboy in forum Bodywork & Interior
    Last Post: 2nd January 2010, 11:58
  5. WARNING - Headlight Alignment!
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2008, 18:28
vectra c headlight on warning
