Results 1 to 3 of 3
Thread: Tyre Profiles
    Regular Member jamesr's Avatar
    Lancashire
    Default Tyre Profiles
    I currently have
    215 55 16w tyres fitted to vauxhall alloys.
    They are an expensive profile, can I change to say:
    225 50 16w without any problems?
    Regular Member LJ sxi-nav's Avatar
    Winchester
    I have 205/55 R16 fitted to my 16s - It's listed in the handbook.
    (as soon as the tread goes I'm gonna fit the SRi 17s I bought off Jamie!)
    Nov 2007
    York
    The 215/55/16 is normally fairly reasonably priced. You should be able to pick up tyres at about £70 per corner which is fine.
    There are only two tyres really worth getting at this size according to the Auto Express tests, Veredstein Sportrac & Continental Premium Contact. Both of which can be bought for about £65. If you're paying any less than that you're buying cheap rubbish!
    If you change size it will gear the car down marginally and increase drag slightly. Probably loose about 4-5mpg on the motorway at 70mph, so wouldn't work out so cheap over the course of two years tyre life!
    James
  1. rough ride on low profiles
    By liam51 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2013, 01:48
  2. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  3. Crd/crd2 Profiles
    By diesel dog in forum Diesel Engine related
    Last Post: 29th July 2007, 12:30
