Results 1 to 10 of 17
Thread: Steering Problems
    Jan 2006
    Dalriada
    confused Steering Problems
    My steering has gone 'funny', it goes from normal to slightly stiff as i turn the wheel, it does this intermittently and at no set point in the steering range. It is rather annoying to say the least so does anyone have any idea's what could cause this??
    I am going to check the steering fluid level tonight to double check this but for the life of me i dont have a clue whats causing it
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    could possible be the pump playing up??
    get it on a tech 2 fella
    Jan 2006
    Dalriada
    Aye i think so mate - i had it in recently and they found nothing
    First thing as you say is check the fluid level - bumper off job!! If it's down then you've probably got a leak.
    Then I'd get under the car, you'll need to jack it up, and have a look at the steering rack for any leaking from it. If it's leaking, and you're feeling it in the steering like you are then it's a new rack!! It may see you okay for a while, but it could just go one day when you least want it to.
    I've had this exact same thing with mine - MOT in May gave an advisory on it for weeping. More recently I saw that it was doing more than weeping. Once I fit my turbo back on again, I'll be getting a new rack for it. If yours is leaking, and given you are under warranty, I'd get it straight down to Vx to deal with.
    If the rack isn't leaking then, as Glynn said, it could be the pump playing up.
    Jan 2006
    Dalriada
    Bumper off job to check fluid ?? Typical i had it off yesterday to fit a new Irmy grilleso looks like it will be coming off again rather sooner than i anticapated - also need to get it booked it ASAP cause its bluddy annoying
    Thanks for the help buddy
    Quote Originally Posted by Steven View Post
    Yup! Vx in their wisdom stuck the bottle in the corner right behind the bumper on the driver's side. I suppose they assumed it wasn't the sort of thing you'd need to check, or top up, regularly - which is true I suppose. Not sure about the facelift, but on the pre you can get away without undoing the rivets on the undertray bit and just remove the wheel arch screws and the two rivets near the headlights and pull it off so it rests on the ground - might be the same for yours?
    No probs.
    dont forget the power steering fluid is green mineral NOT the red gear ep80/90 oil
    Yep, 93160548 for a 1 litre bottle, about £9 odd from Vx.
    Jan 2006
    Dalriada
    Quote Originally Posted by glynn View Post
    Getting looked at tomorrow in the local VX garage - so fingers crossed. They are going to reprogramme the pump and see if this cure's it - if not **** knows whats next
    Thanks for the info guy's
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    wonder wot programming it needs? maybe its forgets to pump?
  1. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  2. Power Steering Problems
    By Brooky18 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2011, 21:31
  3. steering and locking problems
    By whitevanman in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2009, 16:46
  4. Power steering problems !!
    By mark_647 in forum Engine & Drivetrain
    Last Post: 23rd May 2009, 19:10
  5. Steering wheel problems...
    By Harry in forum Suspension, Wheels & Brakes
    Last Post: 6th December 2005, 20:26
