Results 1 to 10 of 16
Thread: front fog loom
    North West
    Default front fog loom
    ive got spade connectors on my front fogs ATM
    I want to finish off properly with proper connectors to make them watertight so no propblems arise
    do vauxhall sell the fog connectors and/or the wiring? (partnumber?)
    OR could anyone else recomend another connector i could use,off another car maybe with same fitment.
    tried ebay for weeks-no luck there
    chears
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    confused
    Tried the local dealer for my Sons Astra H said they do not do them
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the loom is about £38 from the dealers.
    didnt someone use vec b connectors on theirs??????
    North West
    THANKS GLYYN
    Just gone on ebay looking-emailed a seller-and got a relpy right away-payed a few quid for some cocnectors and loom off a vec-b-getting delivered...all under 15minutes
    Thanks for the advice Glynn.
    Will try them and see if they fit,i think they will JOB DONE!!
    North West
    where do u buy the cable tidy things(dunno what they r called),where you put the wires in?
    Also does it need to be a certain type due ti the heat in the under the bonnet
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    Default connectors
    hi there
    i wired up a loom on my vectra c by going down the breakers and taken them of a vectra b model fog wire its not a perfect fit but it works a treat and so easy to do, plus it costs nothing come to think about it i got two spare around the house some where if you cant get them pm me and will post them to you
    North West
    thansks NPH i should have some connectors arriving soon in the post from ebay i'll try them 1st and see if they work
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I bought some wiring convertors for the VXR foglights and i was going to suggest these but they would be the wrong way round, As the extenders fit onto the existing sri foglight plug and then change to a smaller (might be 2 pin) plug for the VXR fogs..
    They were only around £3 each..
    North West
    £5.00 on ebay,hopefully they'll do the job!!
    And the cable tidy part i was after is in the picture below,it goes around the wires.Where's best to buy that from? Need a few metres probably.
    Regular Member skinnyseand's Avatar
    HASTINGS
    I want to install foglamps on my LS what do I need?
  1. For Sale: Front FOG LIGHT Wiring Loom
    Last Post: 14th January 2013, 22:03
  2. Front foglight wiring loom.....
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 18:32
fsegloeom
