Thread: Signum front wobble
    Bournemouth
    Default Signum front wobble
    ok 03' Signum 3.0 Dti
    2 virtually new rear shocks (standard OEM rubbish GM parts)
    Original OEM shocks on the front
    Irmscher springs all round
    18" wheels and 225/45 rubber (2 new Goodgyears at the front)
    Wheels aligned using Hunter laser machine
    Wheels balanced on the vehicle
    After recently kerbing the car quite hard (slow speed but high pressure) I have significant wobble at the steering wheel at 30-50mph, or just plain judder under hard acceleration...
    Is it still wheel balancing?
    Is it alignment (after the kerbing)
    Could it be the knackered front shocks
    What else could cause such uncomfortable jitters?
    thanks guys
    Andy
    Mileage : 000
    Could you have bucked the wheel when you hit the kerb??
    Regular Member mushy2007's Avatar
    Liverpool
    The wheel sounds goosed to me; jack it up and spin it to see what happens
    Bournemouth
    Wheel was checked whilst balancing it... and it was cleared. Scuffed nastily not seriously smashed into kerb.
    Would the shocks contribute?
    Might have damaged a connecting rod/arm or something?
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Agoogy View Post
    Quite possibly. On my last car - Astra G - I slid on ice into a kerb. Slow speed, but a fair impact, and the front NS wheel hit the kerb. I had to have the following bits replaced.....tie rod, suspension arm, Wheel, shock, bearing! and steering knuckle!
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    I bet its the wheel, wheels do balance up sometimes even if bent.
    Swap the wheels from front to back and see what happens.
  1. Replies: 2
    Last Post: 6th October 2012, 23:09
  2. bum wobble
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2011, 12:47
  3. Wobble between 20 and 30 mph
    By Tigger in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2011, 00:28
  4. Front end wobble
    By squekey in forum Engine & Drivetrain
    Last Post: 7th October 2010, 15:03
  5. Signum 3.0 V6 wobble
    By Signum V6 Davies in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2008, 16:21
