Results 1 to 10 of 21
Thread: Back window mists up all the time...
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Back window mists up all the time...
    Yes I know its winter but within seconds of starting the engine my rear window is foged up (sic). Anyone ahve the same probs. Also I noticed the de-mister takes at least 5 minutes to totally clear the window????
    Sunny Dartmoor
    Quote Originally Posted by Stevie-B View Post
    Have the same problem........
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    check the spare wheel well for water
    Regular Member fields's Avatar
    Mar 2007
    Lincoln
    Had this in a Cavalier it was water in the boot the first time then got it again water in the car, carpets wet, the water coming in due to blocked drains below windscreen
    May be of no help but it's got to be damp somewhere to cause the condensation.
    Nicking Ya Dinner.
    You need Demistalyptus, it's great stuff!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Yeah, get this too. I think its pretty normal and running the A/C normally clears it pretty quick.
    I think on mine its because I mainly do short journeys, the car just gets a bit damp, they need good long runs every now and again to dry them out.
    HTH
    Mileage : 000
    Do you keep the A/C on all the time, I tend to and my windows are ok.
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    try changing the pollen filter i had same prob with the wifes astra and changing that solved it
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    Good point about the A/C. If you have A/C on all the time it is quite possible that intially when the car is started the A/C is not drying the air properly and blows out extra damp air. If the windows are below the air dew point then they will immediately mist up. It happens on mine when I switch off the A/C with the fan still running - damp air blown out and mists up windows.
    North West
    My rear window gets soaking wet all the time.There is quite alot of road noise/wind which i can hear from the rear window area also.Could there be an air vent on the rear which lets in AIR?
    On my front window i turn the heater dial to the floor when its parked up,this seems to stop the front misting / even icing up.
  1. Bad time to leave your window open!!
    By kicker in forum Comedy & Humour
    Last Post: 14th December 2012, 10:14
  2. back once again, second time lucky!
    By Monkeyboy6023 in forum Introduce yourself.
    Last Post: 20th September 2010, 04:16
  3. heated back window
    By STREET TWEAKS in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2009, 20:14
  4. i am back one more time
    By speedzone in forum Introduce yourself.
    Last Post: 21st April 2008, 22:40
  5. Back window washer not working...
    By Stevie-B in forum Bodywork & Interior
    Last Post: 2nd April 2007, 08:59
vectra c rear window misting up
Why does my vectra c mist up all the time
