Thread: Best gear change point - 150 CDti
    Rotherham
    Default Best gear change point - 150 CDti
    When is the best point, rpm, to change gear for maximum acceleration?
    I know maximum power is at 4,000 rpm so is it best to change at this point? The rev counter turns red at 5,000 rpm so would holding on be better?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    in order to accurately answer this you will need to know 2 things.
    1. The engine power / torque curve
    2. Gear ratios
    The ideal point is where the torque at the wheels in the next gear up is just higher than the available torque in the current gear.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    it is normally just where the torque tails off near to max revs
    Rotherham
    Thanks Ste. So it's more about the torque than the bhp?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    torque is what accelerates the car, not power directly
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    If you have a standard car then I would change at about 4000 as it dies quickly after that but a tuned one I'd usually hold until around 4750.
    spoons
    Guest
    Quote Originally Posted by nutron View Post
    ..... I change around 5000... but I'm gonna start changing slightly lower, I just get too carried away and keep forgeting..
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Quote Originally Posted by bailes1992 View Post
    My Uncle does that with the M5... driving along and he'll change at the rev limiter when the peak power is way before... he even sings when doing it "just keep revving, just keep revving, just keep revving" My family aint normal
    No Sh!t Sherlock!
    Rotherham
    Standard, company, car. I thought it would be best to change at a touch over 4,000 rpm. It does tend to die much above this.
    Regular Member DeathStar's Avatar
    UP North
    I would say a touch over 4k is you want to keep the revs close to the powerband...the high torque's help get the car going initially as its all about inertia.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Perfect gear change in a 1.9 cdti(150)
    By jay_c2010 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 17:47
  3. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  4. Veccy 120 CDTi Poor Gear change
    By ali06 in forum Engine & Drivetrain
    Last Post: 3rd July 2008, 22:08
  5. Gear box/change
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2007, 23:39
