Thread: Help!!!!
    Regular Member Robclowes's Avatar
    Oct 2007
    Crewe/Market Drayton
    Default Help!!!!
    PLease help
    Fitted CRD2 on Tuesday and have run for the last few days. Car has been cutting out when accelorating away from roundabouts. Not happy with this at all as had kids in car... Any help or suggestions???
    EVERYWHERE
    Quote Originally Posted by Robclowes View Post
    PLease help
    Sounds like an electrical fault.Does it do the same thing with the box and loom removed? Do you have a blanking plug to put in place of the box? This will tell you if the box or the loom is at fault.Failing that,check all the wires for continuity,you may require a new loom.You could also just disconnect and then reconnect it all,you never know,it just might work!
    Oct 2007
    thanks
    Will try that
    Rob
    EVERYWHERE
    thanks
    Will try that
    Rob
    Also try working your way up from the lowest setting to the highest setting on the + and - jumpers,or use a less powerful map of the four available.
    Oct 2007
    Do the (-) settings mean you lose power??
    EVERYWHERE
    No.Even on the lowest setting you will still have more power than standard.I estimate that on the -3 setting you are still putting through 70% of the additional fuel you would use on the '0' setting.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Yep, take it off and leave it off else you could eventually need a new fuel pump . Been there, done that, I see you have a 2006, so would be a Euro4 like mine. They dont tune well. Does yours get a "flat spot" at around 3500rpm where the engine momentarly stops? Then at worse, as you say it'll cut out completely under full acceleration. .
    Take it off and leave it off - it dont work with a Euro4 I've tried 2 different boxes.
