Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Lost me turbo!! - updated
    [Ex]Admin Duncan's Avatar
    Default Lost me turbo!! - updated
    It was there yesterday morning........
    Some of you may remember my posts in the past about losing boost pressure intermittently. Well it started to do it again recently, this time more regularly. If I turned the ignition off and back on again it would come back, so I'd always wondered if it was sensor related - either faulty or getting values it wasn't expecting and going into safe mode. When it had done it in the past it ended up having a new inlet manifold vacuum pressure sensor, which seemed to improve things a bit - but it still did it once or twice subsequently.
    On the most recent occasions, when the boost went it was sometimes, not always, accompanied by an ELM (spanner) light - something that it had never done before, but turning the ignition off and on reset it all and got the boost back. Then one day a week or so ago it went again, but this time the boost never came back no matter what I did - removed the remap, disconnected the battery for a while etc. etc - it didn't come back!
    I did a few diagnostics on the car - checking sensors, boost pressure solenoids etc. (thanks to Rickyroo BTW on the pointers there on how to check them) and all came up fine. The wastgate actuator looked like it was fine and wasn't loose or anything - so I was a bit stumped.
    Bizarrely a few days later the boost came back. Equally bizarrely when I came to the car a couple of days later there was no boost there from the start, but within 30 seconds of setting off it suddenly kicked in! Then a day later it went within a minute of driving off and didn't show any signs of coming back.
    After doing a bunch of Googling and looking on a whole lot of different forums (not Vx or Saab ones but a turbo is the same principle no matter what car it's on) I was convinced more and more that it was a wastegate problem, so I set about removing the actuator arm and diaphragm to see if the diaphragm was working okay and whether the waste gate arm was stuck or anything. Diaphragm tested out okay (just needed to attach a bike pump and put some air through it to see if the rod moved - it did), so I removed the arm so that the lever that controlled the wastegate inside the turbo was now free to move - except it didn't. It had limited movement and felt like something was stopping it from moving fully. Next step was to remove the exhaust downpipe from the turbo - a bit of a number as the bolts have limited access due to the BSR pipe being larger. Got it off, got a mirror to look into the exhaust side of the turbo and saw the problem!!
    Couple of pics after the turbo was removed to explain....
    The turbo. You can see the wastegate actuator (long rod down side of turbo) with the diaphragm attached to it at the top. One of the boost pressure hoses plugs into this diaphragm and as the boost increases the diaphragm moves, in turn moving the rod on the side and gradually opening the wastegate to release excess boost by means of the lever going into the turbo.
    Here you can see the disc covering the wastegate that is opened and closed by the actuator depending on the pressure. The disc is normally held onto the arm by the little pin on the disc being attached to the arm. Here you can see there is nothing holding it! - it's come detached and headed off down the exhaust pipe.
    This meant that the disc didn't lift up as the arm moved, leaving the disc just sliding around over the wastegate hole. The reason for the limited movement of the arm was due to the arm resting on the pin of the disc (which had moved).
    I'm guessing that what had been happening was the disc was moving around and sometimes covering, or half covering the hole so causing boost to vary from what was expected, causing other sensors to pick up these differences and making the car then protect the turbo (safe mode) by releasing the pressure elsewhere - ambient air valve (recirculating dump valve) I'd expect.
    A new turbo from Vx was £500+ - err, I don't think so - so I rang Turbo Technics in Northampton (the people when it comes to turbos IMO - especially Garret ones) and had a chat to see if the disc could be refitted/replaced. Yep, not a problem and it should cost around £60 - bargain!! If they thought the turbo needed a bearing/seal service (replacement) then that'd be £195 - and that would be the turbo rebalanced again on their extremely accurate machines. If they thought there was no need for the service then it would just be the wastegate repair. Given the mileage, 60,000, and the fact that I'll have the car most, if not all, of next year and add another 15-20,000 miles to it - if it was 50-50 as to whether they thought it'd benefit from the bearing and seals service, I'd get it done. Then I'd know the turbo would be okay for all the time I've got the car. I'm in no hurry to remove it all again in the future!!
    So yesterday I got down to removing the turbo for them to collect on Monday. Fairly involved job, but I worked through it step by step and methodically - removing oil lines, coolant lines, sensors, boost pressure solenoids, exhaust downpipe, charge air pipe and other ancillary bits and pieces............
    ....all due to this little bit coming off!! lol
    So, it'll be picked up tomorrow and with them Tuesday. They said it'd be with them for three days, so I'm hoping it will leave them Thursday and get to me Friday so I can fit it at the weekend and hopefully that'll be the end of any of my boost issues.
    EDIT: Latest update here.
    EDIT 2: Now all fitted back on again.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Blimey. Could that have been the cause of the strange results on the rolling road as well?
    I assume you're not going far this week then?
    Best of luck matey.
    And to think a 'warranty claim' would of fitted a replacement turbo.
    Quote Originally Posted by JuzzyD View Post
    Yep, quite possibly.
    lol - nope, car's going nowhere until the turbo is back on.
    Tyneside
    ****** hell, good to see you found the problem D, and such a small part to cause a major thing to happen.
    Hertfordshire
    Well at least you found what it is m8, and by the looks of it should be a simple enough fix !
    Chester
    Great diagnostic work to find the issue. If all it ends up costing is £60 that's one hell of a result.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    More to the point, I bet your well proud of yourself for basically finding and sorting the problem in a self taught way. Well done.
    Quote Originally Posted by Stevel View Post
    - cheers chaps. Yep, was rather pleased that I managed to work all the way through to then isolate the wastegate as being the problem.
    Yep, here's hoping! Worst case scenario should hopefully be that it has a bearing and seal service - which would make sense to get it done now while it's out.
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    Ok so thats £500 for the turbo and what say 3 hrs work to remove and refit the new turbo at say £90 and hr so you jus saved yourself £570 with the refurbishment on your current turbo lol! Good effort!!
    Now what are you like with plastering I reckon you could save me a packet lol!!!!
  1. Updated pic
    By ADE34 in forum Quick Photo Album
    Last Post: 25th September 2011, 20:18
  2. can my sat nav be updated?
    By hovis007 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2010, 15:17
  3. Lost my turbo too!
    By garthmatthews in forum Engine & Drivetrain
    Last Post: 7th August 2008, 19:22
  4. Updated pics
    By daviek in forum Quick Photo Album
    Last Post: 31st October 2007, 11:44
  5. Lost my turbo!!!!!!!!
    By Duncan in forum Engine & Drivetrain
    Last Post: 24th July 2007, 21:16
is leaking steering rack covered under network q warranty
