Thread: Symptons of an expensive xmas!!
    Oct 2007
    Ripon
    Default Symptons of an expensive xmas!!
    I have a 05 1.9CDTI that has started to rattle a a little. After joining the fourm and looking around I have been looking into things people have found wrong.
    My rattle is when the Car is in neutral and the clutch depressed and lifted to bite point i have a rattle noise, noticeable but not over loud.
    If the good old DMF problem what are options if VX failed to sort .... Warranty ends 180308 .......
    Any other garages fit for cheaper ...... manchester area???
    Also does it get worse of just keep on with annoying rattle???
    Full Member Big Sig's Avatar
    That sounds like a dual mass flywheel problem. Its still covered so get it in!
    Nicking Ya Dinner.
    Three things, flywheel, clutch or gearbox bearing, you need to get it looked at asap while it's down to them, and don't be fobbed off either.
    Oct 2007
    Ripon
    don't really notice anything when moving off ..... odd diesel rattles here n there.... no strange looks off passer bys! Just stationary.
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    Sounds exactly like like the DMF problem I had - rattles just as you disengage or engage the clutch. Mine also caused the clutch pedal to 'wobble' when I rested my foot on it very lightly as I was diving along in gear and was worse in second.
    Get it replaced under warranty.
    Oct 2007
    Ripon
    Best to be up front with them or play along and say ... don't know what this is!
    Aug 2007
    Kent
    Well, when I went in to the dealers I already had a long history with the problems so I was totally upfront. One of the techs took the car out and agreed with my observations and it got fixed.
    What I did ensure though was that I demonstated the noise, such as when the clutch was depressed. At least this way I took control and was showing him the problem. I also went with him on the test drive.
    If I were you I would go in and explain the symptoms and just mention that you think it may be the DMF.
    sheffield
    Know doubt mate its the DMF!
    exact same problem on mine as reported on this forum some months ago.
    dont take any rubbish from the dealers about wear and tear its a flywheel and should last the life of the car mine went at 73k miles and was eventually payed for by Warranty Direct,which was obviously a warranty I took out following my completion of the standard VX 60K warranty period, which its about time VX extended!
    Hyundai at 5 years unlimited and Kia at 7 years (ok drive train only) so come on VX give us loyal guys some peace of mind and incidentally did you know that all Hyundai cars in the USA have a TEN year warranty!
    cant see our local VX dealers giving that sort of warranty while the sun is still up in the sky!
    pete mc
    Nov 2007
    staffordshire
    just had a clutch and dualmass flywheel fitted today all in for 500 quid a bargin i think or do you know better?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i have had 2 dmf kit's fitted under warranty now, one because of an oil leak and the other due to a rattle noise on cold start up, get it in and tell them it want's sorting, it is a known problem to vx on these car's and there have been 2 new one's released to cure the fault,
    hope you get this sorted out mate
    Midlands Mod Shop - NFFC.
  1. Been an expensive day so far.
    By MattVecVXR in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 17:06
  2. This is getting expensive
    By blackbeauty in forum Styling
    Last Post: 2nd October 2011, 22:37
  3. Most expensive re-map!!!
    By mushy2007 in forum Engine & Drivetrain
    Last Post: 10th March 2009, 23:46
  4. Xmas card to you all - Merry Xmas
    By MalcGSI in forum Comedy & Humour
    Last Post: 10th December 2008, 17:06
  5. symptons of being over 25
    By dazza1964 in forum Comedy & Humour
    Last Post: 16th July 2007, 09:45
