Results 1 to 10 of 11
Thread: Sport Buttons, What Do They Do?
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Default Sport Buttons, What Do They Do?
    Contemplating chopping the Vectra in for a Zafira as it's not really coping as a family car and drinks fuel so it does need to go eventually
    Anyway wanting to stick to a sportier model have been looking at all sorts but liking the SRI which has a sport switch to stiffen up the suspension. Am I realy going to use this is what I keep asking myself realy
    From a maintenance point of view how does it work, does it use a different shock for this feature to a standard car, will one be extortionately expensive to replace just to support this feature which won't be used I'd of thought.
    Full Member Big Sig's Avatar
    Its supposed to sharpen up the throttle as well, but I think your right on the cost of possibly replacing the shocks at a later date..... But then, when was the last time you replaced a set? in my experiance, not very often. In the astra sri I test drove, all the sport button did was light up! I notoced no difference in it at all!
    [Ex]Admin Duncan's Avatar
    The sports button can do a few things depending on the spec of the car - sharpen throttle response, sharpen the steering, stiffen up the suspension and switch to different map to up the power. Not all cars with a sports button have all four features.
    To stiffen up the suspension you'd need to have the shocks that can be stiffened up from the control of the ECU - and they are significantly more expensive that standard ones. IIRC I heard something like £400 a pop being mentioned!
    Chester
    The missus Astra has the sports button and there is definiatly a difference with it activated.
    The steering is more direct and the throttle is kinda on/off if that makes any sence.
    Not felt any difference in the ride quality though. The standard ride is pretty firm anyway. Especially compared to my Vec.
    Edit. Just seen Duncans post. Her car probably hasn't got fancy shocks.
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    my bro in law has the astra sri and also sport button, small fifference when pressed and slightly noticeable.
    If the Sports button gives more power better responce, then surely Vauxhall would mention thatin the sale of the product,
    IE the sri cdti 150 is 150 without the sports button pressed and higher with.
    My idea was that it runs lower than 150 until the button is pressed and then raises to 150
    just my Ideas
    As I said, not all cars with the sports button have the two different power settings. e.g. on the Vectra what it does is sharpen up the throttle response - basically makes it more sensitive so that the same amount of travel on the pedal gives more revs than with the button out.
    Herts\Beds Border
    I know the sales brochure does say about the ride being stiffened up.
    £400 / shock, that's scary
    I did hear Clarkson going on about the shocks on the R8 I think it was saying they have iron filings in the fluid and when voltage gets put through, the filings get magnatised and bond together meaning there's less room for the fluid to move.
    I'd expect to pay £400 for a shock on one of them but not a Vauxhall.
    Jul 2006
    I'd rather spend the £400 on a full setup from Eibach, Irmscher etc, and have the superior handling all the time TBH.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i once priced up an electronic controlled suspension set up for my work car to stiffen up the rear end and it was going to cost £458.00 + vat, it was called the outback option if i remember corectly........needless to say i knocked it on the head
    Midlands Mod Shop - NFFC.
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    I often drive the Zafira's as hire vehicles and can agree with the above, they make NO BLOOMIN DIFFERENCE its a gimmic. OK it might stiffen the suspension (doubtful) but would you notice? the ever changing road surfaces in the UK would negate it. Go and take a test drive, trust me if your looking for a turbo like difference then forget it, it isn't noticable unless you want to (imagine it) notice it.
    Me and a friend were driving from Inverness to Kinloss everyday for 2 weeks in one and we had the sport button, EITHER of us driving the other pressing THE button NO DIFFERENCE, both of us. Dont spend any extra on it.
  1. key fob buttons
    By IRvectra786 in forum Bodywork & Interior
    Last Post: 30th September 2012, 03:35
  2. Replies: 3
    Last Post: 2nd November 2010, 17:58
  3. I wonder what these buttons do...
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2010, 16:52
  4. Replies: 1
    Last Post: 25th September 2009, 22:59
  5. Car buttons.....
    By bertbuckie1 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2009, 20:48
