Results 1 to 3 of 3
Thread: Signatures.
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Default Signatures.
    Hey, as a new member i've noticed my posts look nowhere near as good as the rest of yours! How do i create a fancy signature strip at the side and bottom??
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    go into your user cp at the top of the page and look down the left hand side you will see avatar click on thet and you can upload a pic for this, and the same for the signiture
    hth
    Midlands Mod Shop - NFFC.
    Here, there and every where!
    Just remember to make sure they are the correct size or the forum software automatically rejects them
    11. Signatures
    A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 100k.
    A single of line of text, linking to an external photo host (car pics etc) is also permitted under the above graphic signature.
    If no images are used then up to 4 consecutive lines of normal (size3) or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
    Although any interested member is welcome to take part on the forum, we would ask that signatures are kept in keeping with the intended theme of the Forum, ie Vectra C’s and Signums. The majority of members are here due to that common interest and we would like to maintain some consitency. Avatars are more relaxed and as long as it is not offensive then subject matter is unrestricted.
    12. Avatars
    Avatars are viewable by everyone, so any user Avatar must be free from any lewd or profanic material. The maximum size permitted for Avatars is a 150x100 pixel frame with a file size of no more than 50kb. Lightly animated GIF files are allowed, but static JPG files are preferred.
  1. signatures
    By mickeyc in forum Signature & Avatar Testing
    Last Post: 23rd April 2007, 12:36
  2. Ian T - Signatures
    By spoons in forum Signature & Avatar Testing
    Last Post: 15th January 2007, 23:08
