Results 1 to 3 of 3
Thread: Air Con Rattle
    dudley
    Default Air Con Rattle
    I have had the car back from the dealers and they have supposed to have replaced the air con compressor because of a constant rattle when the engine was hot. It was noisy enough to sound above the noise of the engine. However, the new compressor is more noisy, but comes and goes. It could be the outside temp. causing the compressor to turn on/off?
    Also, the rear screen is slow to clear when the air con is, but that could be the weather, although it does not seem that cold coming out the facia vents.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    stupid question but is your heat setting right down to coldest point.
    dudley
    On the dial, yes, unless the control is faulty
  1. DMF rattle
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2013, 13:31
  2. 2.2 with a rattle
    By MORGIE8153 in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 14:17
  3. Bad rattle!
    By heheshamon in forum Bodywork & Interior
    Last Post: 16th April 2010, 20:37
  4. A rattle at 70
    By Jezza181 in forum Engine & Drivetrain
    Last Post: 25th March 2009, 08:02
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
