Thread: how much
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    Default how much
    getting dual exit exhaust soon .want to change the rear insert .how much is it to spray the vxr insert .the normal sri one is £55 +vat a bit over the top not sure about the vxr one though
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    its the price of the paint as it is all water based now so the prep the part prime it and then paint it stright after now as wet and wet .
    May 2007
    manchester
    think i have been mis-understood.want a rough idea of price to paint the vxr insert .the £55 is to buy the normal insert sri from vauxhall .the vxr one is £25+paint .so basicly is it more than £30 to paint the vxr insert on a budget of the wife for christmas for the exhaust
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    paint it yourself mate, with rattle can's from vx or a nice satin black like mine
    Midlands Mod Shop - NFFC.
    May 2007
    manchester
    is the vxr insert easy to fit and where did you get the satin black paint from ?did you put laquer on it after painting it ?
    Regular Member mushy2007's Avatar
    Liverpool
    If you get it to me in Liverpool I may be able to pull a few strings for you.
    I have two friends in the car body business!
    Trim : Get a
    Quote Originally Posted by johnnyg View Post
    not easy but not hard at the same time just akward........
    i got the black satin paint from my local motor factor's and i didn't bother to laquer it as it came out great, vxr part ready primered so just a rub down with 1000 grit wet and dry, wipe clean then apply the paint, all done in about 20-30 mins, leave to bry for a day or so and then the wrestling match begins
    Regular Member icetrix's Avatar
    bangor
    its a gift, i jus sprayed my insert and lower spoiler but then again i used to work in a bodyshop, the centre insert comes primed so jus needs flattened with a bit of 600 wet & dry then a few coats of paint and if its metalic give it a lash of laquer
