Thread: 2003 2.2 SRI Vectra: Intermitant Knocking Noise
    Regular Member sophos9's Avatar
    Norfolk
    Default 2003 2.2 SRI Vectra: Intermitant Knocking Noise
    Hi,
    Got a strange noise coming from the drivers side front and rear (not at the same time). This is totally intermittent and happens on all variety of roads, sometimes you will not hear it for a few days then it will do it several times consecutively?
    It almost sounds like a spring is knocking out of place? I've looked over the components and everything looks fine, any ideas?
    Cheers!
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    If a coil spring has broken, the bit that has broken off sometimes sits in the bottom of the strut until it bounces out, it makes a noise! If you feel the coil spring at the bottom, it should be square, if its jagged, then its broken and both front will need replacing.
    Exhaust rubbers missing.
    Suspension arm bushes worn and or other suspension components.
    Regular Member DeathStar's Avatar
    UP North
    Could be the roll arm bushes....that happened on my last veccy and astra
    anywhere
    from past experiance on my vec b it was the drop links on the end of the anti roll bar. Covered under warranty, but i wouldnt think to much to get replace. can happen a lot with big wheels
  1. 2003 Vectra C 1.8 Petrol Timing Belt Noise
    By chrisjt31 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:21
  2. Vectra C, 2002, Rear Suspension knocking/creeking noise
    By richardkay007 in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2012, 19:05
  3. Vectra 2003 2.2 SRI DTI front creaking noise
    By ramzy304 in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2010, 21:57
  4. vectra 1.8 duelfuel 2003 knocking at rear
    By sparks in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2010, 00:39
  5. knocking noise on my vectra
    By vectranath in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2009, 21:59
