Thread: Strange Radio Tuning Problem
    Regular Member sophos9's Avatar
    Norfolk
    Default Strange Radio Tuning Problem
    Hi, wonder if you can help iwht this strange problem. The CD/Radio on the 2.2 SRI 2003 Vectra C is doing something really wierd, it will not tune into even number
    i.e. If I want FM 102.4, I cannot get it!! If I want FM 99.3 I can get it now problem
    Can someone help please?
    Jul 2006
    Not sure what radio you have - is there an option in the settings to adjust the step size when tuning?
    Can you auto-tune in using RDS data instead of the frequency?
    Norfolk
    Not sure what radio, will check later. Autostoring using RDS does not pick up any of the stations on equal frequencies either
    Have looked through the manual and there are no options to choose the step of the frequency either, very weird??
    6 Post(s)
    Try turning off the RDS and you should be able to then scan manually.
    Norfolk
    Hi mate, thats the problem..... When you manually tune it will only use odd numbers
    i.e. 99.3 - works fine. 102.4 does not work
    6 Post(s)
    If all else fails, pull the fuse (to disconnect the power to the stereo) and reconnect again to see if that then resets it.
    MAKE SURE you have the security code first though.
    If the stereo has the 4 disc cd changer and tape deck, then it's *probably* the CCR2006 that's fitted.
    Norfolk
    Right pulled the fuse (then lost it down the side of the trim)
    Got a new one and tested, radio still only tunes to odds as described above. Did not check the radio type however its the unit with a single cd player, RDS TP etc etc....
    Any more ideas?
    Jul 2006
    One solution - £50 for a cheap aftermarket HU, fascia and wiring loom!
  1. Strange problem.
    By Chad! in forum Engine & Drivetrain
    Last Post: 13th October 2011, 14:18
  2. radio tuning problems, help anyone.
    By melvyn8181 in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2011, 21:26
  3. Strange electrical problem regarding radio controls on steering wheel
    By eaglepva in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2011, 17:36
  4. Dragon tuning box, Strange connector
    By Marky in forum Diesel Engine related
    Last Post: 14th November 2007, 14:27
  5. Very Strange Problem
    By Ben H in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2006, 17:32
