Results 1 to 10 of 16
Thread: I've seen the light!
    Jul 2006
    Default I've seen the light!
    Adjusted my headlights last night using the Lawson Technique and it's like driving a different car!
    It's amazing the things I can see now.......road signs, other cars, pedestrians....
    Nice one, Duncan I can see this joining the airbox mod on the list of 'first things to do when you get a Vectra C'!!
    Jan 2006
    Skynet HQ EMEC#5
    I think I'll have to give it a try, the Lawson Technique sounds very official
    Regular Member siross's Avatar
    Oct 2007
    Sounds good, would this make a huge difference to the facelift model?
    Regular Member Graham SRi 2.2's Avatar
    Andover
    Not sure about the facelift model but it defintely makes a huge difference to the pre f/l. I did this along with upgrading the bulbs and because I needed to take the airbox off, I de-restricted it at the same time.
    It's like driving a different car at night - I can see
    This should definitely go on the list of 'First things to do!'
    Jul 2006
    Mexico
    Quote Originally Posted by parapaul View Post
    Mate can you tell me how many turns you gave to those allens? Don`t want to over do it and blind people all over the place
    [Ex]Admin Duncan's Avatar
    Nice one, Duncan
    Glad it worked for you m8 - does make a difference doesn't it!
    PMSL @ 'Lawson Technique'! Sounds like some 'recreational athletics' position!!
    Quote Originally Posted by BlueRob View Post
    Rob, as in my original thread, it's not the number of turns of the allen screw you need to take note of, it's where the beam sits on the wall/garage door. You simply mark the beams when they are on position zero, turn the ranger adjuster on the headlamp switch to position 2, then use the allen bolts to lift the beams back up to the marks you made. Then your position zero is your new, extended range, setting and position 2 is the one that then gets you back to the original 'correct' setting for any MOT, or whatever you have over there, tests.
    Here, there and every where!
    ....one thing you forgot Paul....................THE ROAD
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Well, it would be a cheaper mod to make than buying a set of HID's.
    Going to try this tomorrow and see how it goes.
    Cheers for the detailed description, Dunc.
    Tyneside
    Just ordered some bulbs and will get it done over the weekend hopefully.
    Jul 2006
    Mexico
    PMSL @ 'Lawson Technique'! Sounds like some 'recreational athletics' position!! Rob, as in my original thread, it's not the number of turns of the allen screw you need to take note of, it's where the beam sits on the wall/garage door. You simply mark the beams when they are on position zero, turn the ranger adjuster on the headlamp switch to position 2, then use the allen bolts to lift the beams back up to the marks you made. Then your position zero is your new, extended range, setting and position 2 is the one that then gets you back to the original 'correct' setting for any MOT, or whatever you have over there, tests.
    aHA! Now I get it, Thanks Duncan Now I got a clearer picture....slap me
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
