Results 1 to 10 of 25
Thread: How do i get the code in!!
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Default How do i get the code in!!
    Right, Radio is now in, but how do i get it to display the 4 ---- where i entrer the code....
    I know how to enter the code once its displaying the ---- but i cant get it to do it..
    Mark showed me a while ago, but i have forgotten it!
    Its a CCR 2006 if it makes a difference.
    Jul 2006
    Mexico
    Using Buttons 1,2,3,4....botton 1 for the first blank....lets say the no. is 1212 so botton 1 pushed two times (first blank) then botton 2 pressed 3 times (second blank) and so on...after the code is in press AS until confirmation.
    hope that was clear
    [Ex]Admin Duncan's Avatar
    Press the AS button and whilst still holding it turn on the unit. Keep holding AS until you hear the beep and you see the 10 ---- in the display. Enter the code and once done hold the AS button until it beeps again.
    May 2007
    Dartford
    Is it the same procedure for a Siemens VDO 2005? (04 LS)
    Ive just done the air box mod and fitted a GSI air intake, then disconnected then reconnected the battery to reset the ECU. The radio just says "SAFE" on the screen. Also since doing this my windows dont go all the way up or down when you hold the button for a sec, you have to keep the button pressed in, as soon as you release the button the window stops?!?
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Quote Originally Posted by tempo View Post
    Yep.
    For the windows, just wind 'em up on the button, and hold the button down when it gets to the top for a few seconds. Repeat for the other windows.
    Phil
    May 2007
    Dartford
    Cheers mate, got the windows sorted. Holding AS as i turn on the radio and keeping it held down doesnt seem to do anything? No change on the screen and no beep? Does it matter where ive got the key turned to in the ignition?
    Jul 2006
    Mexico
    Yes mate the ignition has to be on..press AS and the turn ON knob and keep pressing them...you`ll hear a beep and the screen should show 10_ _ _ _ (10 is the number of times you have to input the correct code )
    May 2007
    Dartford
    Cheers will give it a go when i get another chance to pop out, had a boring drive into work this afternoon with no working radio
    Jul 2006
    Mexico
    yesssssss....music is a most! hope you sort it soon....keep us posted
    Jun 2007
    Right, something i learnt after entering the incorrect code 3 times, If you do enter it wrongly 3 times, leave the radio on for 10 - 15 minutes in Safe ode, then it will give you another try, For each time after it you get it wrong, it will take longer than the last before offering you another attempt. After the 10th time of failing, the radio is scrap, So Mark told me anyway!
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. code anyone ?
    By hippo in forum Vectra C / Signum Troubleshooting
    Last Post: 13th November 2011, 22:47
  3. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  4. code for cd 40
    By Eddie Dee in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2007, 01:16
  5. Key Code
    By HB39AA in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2006, 15:50
