Results 1 to 10 of 15
Thread: Hydraulic Bonnet Lifters?
    Nov 2007
    Kent
    Default Hydraulic Bonnet Lifters?
    Just bought a new vectra, so its an 57 C, really pleased with it
    BUT
    Because I'm in a I can't get the bonnet open and hooked up aargh.
    Didn't think to check when I bought it. My old vectra had hydraulic dampers which lifted it for me.
    Does anyone know where I can get hydraulic lifters for my car? I at least need to be able to get to the washer bottle and stuff. All the ads I've seen only mention vectra B's.
    Thanks for any help
    Dom
    Regular Member badge25's Avatar
    Mar 2007
    west midlands
    I know these are fitted to the pre facelift model so might be worth a trip to the stealers to see if they fit. The bonnet on the facelift is much lighter than the pre face version so dont know if this is the reason they didn't fit them. Or it could just be another vx cutback.
    Regular Member DeathStar's Avatar
    UP North
    Thats another thing I have noticed, its ok if you tall as the bonnet seems to be pointing to the sky when hooked on. If you are short or disabled it would be a nightmare to locate the bar into the bonnet, The Lifters were better!
    Regular Member mushy2007's Avatar
    Liverpool
    Another cutback me thinks!
    I nearly cut me flamin fingers off, when i got the facelift model as i lifted the bonnet i let go assuming it had lifters!!
    As they say assumptions are the cause of every **** up!!!
    UP North
    Quote Originally Posted by mushy2007 View Post
    Yip, that what happened to me also, and I nearly dropped it this morning onto my fingers!
    11 Post(s)
    I nearly cut me flamin fingers off, when i got the facelift model as i lifted the bonnet i let go assuming it had lifters!!!
    Funny you should say that. I did almost the same thing myself. When I asked the local garage why the lifter is no longer fitted, the excuse they gave me was the bonnet isn't as strong as the pre facelift (as it's basically a flat panel instead of having a bend in it for the incorperated radiator grille) and there's every chance the bonnet could bend when trying to close as it's weaker.
    All that I know is when I've gone to shut the bonnet and forgot there isn't a lifter anymore, the bonnet stay bar bent before the bonnet did!
    Unfortunately its not an excuse... the bonnets on the pre facelift were steel... facelift bonnets are aluminium and are a lot less strong... apparently they twist and buckle with the gas struts, so a normal strut is fitted instead.
    11 Post(s)
    Quote Originally Posted by Jamie View Post
    The bonnet on my 53 reg (registered Jan 2004) was aluminium. I can remember seeing a write up somewhere that along with some of the suspension components, the bonnets were also aluminium on all the Vectra-C's; both pre-facelift and current.
    EDIT Found it:- http://www.channel4.com/4car/road-te...noforward=true
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    IIRC the pre-facelift bonnets are steel framed with alloy skin and the facelift bonnets are all alloy and not strong enough to take the pressure from the hydraulic struts.
    I think VXL test fitted them but the bonnets were getting warped so stuck with the old type of strut.
    HTH
    Nov 2007
    Kent
    I figured it. I'll keep a block of wood in the boot, slide it under the front when I release the catch to stop it shutting/crushing fingers, move to the side, lift the lid and lock the stay bar. et voila
    Thanks for all the replies. I won't bend me bonnet.
    More than one way to skin a cat
  1. Bonnet hydraulic arms?
    By Danny87 in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2012, 07:47
  2. Hydraulic bonnet rams/lifters
    By rimotu66 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 11:56
  3. Bonnet lifters
    By Keith Fusco in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 22:39
  4. Hydraulic Bonnet Lifters
    By Brutus in forum Bodywork & Interior
    Last Post: 15th November 2009, 19:14
  5. Hydralic 'bonnet lifters'
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2007, 10:20
vectra hydraulic lifters bonnet
