Thread: Removing Rear Door Cards?
    Jul 2006
    Question Removing Rear Door Cards?
    I know there's a brilliant How2 Here for removing the fronts, are the screws and plugs in the same places for the rear doors?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Pretty much.. although if you have the winders rather then the electric rears (like me ) they can sometimes be a pain to get off (need to push the pins out)..
    Nov 2007
    York
    Best way to get the circlips off the winder handle stem (without a miniature external circlip plier) is to bend the end of a small (3-4mm) flat blade screwdriver.
    You then press the door card firmly back from the handle, slip the bent screwdriver head between the open ends of the circlip and push apart.
    Jul 2006
    cheers
  1. Help. Trouble with removing front and rear door cards.
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2012, 14:54
  2. Removing front and rear door cards for speaker upgrades help
    By hothatch in forum Bodywork & Interior
    Last Post: 7th August 2012, 20:22
  3. Rear door cards.
    By badback in forum Bodywork & Interior
    Last Post: 31st July 2009, 09:01
  4. Removing door cards...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2007, 00:14
