Thread: 1.8 won't heat up - Bl**dy freezing!
    Nov 2007
    Lanarkshire
    confused 1.8 won't heat up - Bl**dy freezing!
    My father has a 1.8 and it won't heat up!
    It just never worked when he got in it this morning.
    I have read a fair bit about it on forums and need a help as to where to start.
    Is the thermostat stuck closed? How do i test it?
    Is the Heater Matrix blocked? How do i diagnose this?
    Is the linkage from the controller disconnected some how? Where is it?
    I am not sure where to start, how to start or if it could be something else.
    He uses the car for work and i fear his feet will freeze before it's fixed.
    Many thanks for reading this and i am grateful for any advice
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    I had a sierra (yes I know..sorry!) with the same problem.
    Whatever I looked at it wasnt it.
    In the end I took it to the garage, they sorted it in a morning, turned out heater matrix was knackered!
    Nov 2007
    Lanarkshire
    Still not sure how to test the matrix?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    sound's like the stat to me mate, but couldn't tell you where it is so you can get it out to test, if you know i used to boil the kettle and drop it in if it opened then it was ok if not it was foooooooked, best idea is to go to the dealer's and get it sorted
    hth in some small way
    Midlands Mod Shop - NFFC.
    Nov 2007
    Lanarkshire
    Thanks to Sonic boom and ditchp for the advice.
    I will just have to dig around and have a look.
    If anyone else can help i would still appreciate some advice?
    RCB
    Regular Member simac's Avatar
    Wirral
    My 1.8 is taking longer to warm up now the colder weather is here, how far is it being driven/how long are you giving it to warm up ? can take mine a good 5 miles when it's only 1oc like this morning.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Does the temp gauge show any temp or does it just sit a zero? If gauge shows a very low temp I would change the thermostat (front left side of head - two water connections and one temp sensor wiring connector to remove). Funny old thermo' with two lugs that have to be located under lugs in the casting but no prob as tool is supplied with thermo to ease fitting.
    Nov 2007
    edinburh
    silly question, but is the radiator in good condition?
    if it is busted or low in fluid, the hot liquid wont reach the higher part of the engine, so the air intake wont get heated. i had that problem in my honda a few weeks back. just tossed the radiator and got a new one.
    if this is the case, i'd recommend bleeding pout the radiatior in full and filling with anti freeze, it is winter after all!
    to empty the radiator, just unscres the little plug at the botom and leave to drain.
    then tighten that back up and open the bleed nipple at the top of the hose coming from the radiatior and fill with antifreeze. this can tke a while so be patient, as the air needs to clear from the system completely, or your back at the start. just keep filling til fluid is running from th nipple. (stop laughing at the back)
  1. i am freezing
    By parkroad in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 19:43
  2. Windscreens - Heat absorbing or heat reflecting?
    By Caveman_nige in forum General Motoring Chat
    Last Post: 4th February 2013, 22:09
  3. No, no, no, GT5 keeps freezing!!!
    By rushy in forum Games Room
    Last Post: 28th December 2010, 13:57
  4. its bar-steward freezing here.....
    By bobby-tupper in forum General Chat
    Last Post: 10th January 2009, 17:21
  5. Freezing this morning
    By Sean-2.2Direct in forum General Chat
    Last Post: 3rd December 2008, 12:03
vectra wont heat up
Vecrea c 1.8 heating wont walm up at all
