Results 1 to 10 of 20
Thread: Loose leather trim
    Regular Member crucial's Avatar
    Oct 2007
    kent
    Default Loose leather trim
    On the drivers seat on my 2003 elite, the leather seems to of pulled out of the side by where the side airbag is. Can anyone help me refit it? do i have to remove the airbag, and if so how? or is it just pushed in between the airbag and plastic surround. Is it danagerous to go prodding around by the airbag? Help greatly appreciated, i dont want to rip the seat out unless i really have to.
    [Ex]Admin Duncan's Avatar
    Just get a plastic wedge, or something similar, and push it back behind the plastic airbag surround thing. You're not going to disturb anything. Exactly the same thing happened with mine recently and that's what I did.
    Tyneside
    Mine done this, i've put it back in, but it's not as tidy as the passenger seat.
    Regular Member lborob17's Avatar
    Rainy Derbyshire
    my 'design' seats did that too - but after pushing it back in it never came out again!
    Jan 2006
    Hornchurch
    just unclip the back ok the seat at the bottom on the base
    then pull the flap up
    get a 8 or 10mm socket an undo the airbag push the leather back in and do up the airbag
    job done alomst
    push the back part of the seat back into the clips
    have a cup of coffee
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I've done the same myself. Use an expired credit/debit card as a 'wedge'.
    Oct 2007
    kent
    Thanks a lot everyone, i just jemmied it back in with a credit card. To start with it came out a couple of times, but after forcing it in a bit further it seems well again. Im not majorly impressed with the quality of the interior so far though. I knew i should of bought a BMW 540i
    Oct 2007
    kent
    Eek
    It come out once more. Does anyone know if the leather is glued or otherwise held in behind the seat airbag, it just keeps popping out
    Regular Member cameraman's Avatar
    Leicester
    It's a cr*p design my old 03 plate had a new seat cover under warranty but it still came out, the facelift seems a lot better, however I've had a full leather retrim so confident it won't happen again. The leather is clamped into place by the airbag, I think it should have been glued/stapled into place.
    Jan 2006
    Hornchurch
    undo the air bag an do it up with the leather under it
  1. Loose Trim
    By Matt Cutler in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 17:08
  2. leather trim
    By kenny1zero in forum Styling
    Last Post: 15th May 2008, 18:42
  3. signum half leather - design trim and vectra full leather
    By TIMMAH in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 11th May 2008, 22:56
