Results 1 to 10 of 17
Thread: z19dth TURBO problem ?
    Regular Member dinac_cro's Avatar
    Nov 2007
    Zagreb/Croatia
    Default z19dth TURBO problem ?
    bought car before 1-2 weeks and have problem ...
    i the morning when it is cold i start engine and i hear some noise under the hood when i give some "gas"
    noise is like owl sound
    lets say like this sound but only not that short :
    "Otus flammeolus - Flammulated Owl" - http://www.owlpages.com/sounds/Otus-flammeolus-1.mp3
    but after 2-3-4 minutes of riding, noise go away
    sry on bad english
    problem with turbo ??
    Nov 2007
    Zagreb/Croatia
    here it s original sound recorded :
    http://www.justupit.com/232db2cdc280...d12e65bdcb51e4
    Regular Member david.aka.judas's Avatar
    Suffolk
    and i thought mine sounded rough, good luck and i hope you get it sorted.
    Nov 2007
    Zagreb/Croatia
    I cant find anywhere what model of turbo is on that z19dth, 2004. engine ? maybe some1 know?
    Regular Member Karl's Avatar
    Sunderland
    if it stops when its warm it may be a wastegate sticking?
    Nov 2007
    Zagreb/Croatia
    hm ... some guy here in CRO told me same as You !
    So.. if it is that WG , is it a "bad thing" ? i mean what can happen if i dont repait turbo couse it is little expensive thing
    Sunderland
    I would wait for someone more technical than me. But I would think it can't be good for the car.
    [Ex]Admin Duncan's Avatar
    That whistling could be due to a turbo imbalance (less common) or an air leak (more likely). Check all your hoses for any splits, and they can be quite small to cause a problem and all the connections as well for any leaks.
    As for the specific turbo model in that engine, I couldn't find what it is.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Sounds like a cold engine to me and the Turbo whistling ,
    If you have a bit of a rattle when cold pop in some Oil additive , JML do a good one or are there some ceramic ones now,
    Nov 2007
    Zagreb/Croatia
    Thx guys i will report when i find couse of that funny noise
  1. z19dth turbo will it fit z19dt
    By zippygsi in forum Vectra C / Signum Troubleshooting
    Last Post: 7th October 2011, 08:04
  2. Z19DTH 150 engine problem;/
    By kenzohusky in forum Engine & Drivetrain
    Last Post: 19th June 2011, 16:59
  3. problem with z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 27th April 2011, 19:20
  4. 2.2 dti Turbo problem
    By Shortland78 in forum Engine & Drivetrain
    Last Post: 18th February 2011, 14:34
  5. Turbo Problem...
    By dankidd in forum Engine & Drivetrain
    Last Post: 11th August 2008, 22:55
z19dth turbo whistle
