Thread: 1.9 CDTI 150 Fuel pump failure...help!
    Mar 2007
    Gloucestershire
    Default 1.9 CDTI 150 Fuel pump failure...help!
    On my way to work and the car cuts out....in short my local garage have said the fuel pump in the tank has gone. Typically my warranty ran out on the car 5 days ago!! I am waiting for a price back from my garage for the part, but does anyone rate my chances with going to Vauxhall and seeing if they would contribute as I suspect it wont be cheap. The car is just 3 years old with 38k on the clock..
    Full Member Big Sig's Avatar
    with only 38k and 5 days out of warranty i'd 100% expect them to contribute at least 60% if not 100%!
    Get to your local VX garage and have a word with the service manager. I have had them pay when out of warranty.
    Best of luck!
    Mar 2007
    Gloucestershire
    Thanks for that. Would they only contribute if they carried out the work? The problem I have is getting the car the 10 miles to the dealer as it is not running.
    Oct 2006
    Yorkshire
    Mar 2007
    Gloucestershire
    update.....my local garage have just returned the car and tell me the pump in the fuel tank was shorting out. The fuel was sloshing about and caused the two wires to touch, which as it happened were not insulated. Going to see how it goes but fingers crossed. On a side note when i phoned the main dealer to get a price of a pump I was told there was only one, which cost £915 plus vat??? obviously there are two but they didny know this. Thanks for the replies, cracking site
  1. Vectra 2.0DTi fuel pump failure
    By Davyturner in forum Engine & Drivetrain
    Last Post: 29th January 2013, 17:33
  2. Replies: 7
    Last Post: 9th July 2012, 23:52
  3. Options for DTi fuel injection pump failure
    By circushead in forum Engine & Drivetrain
    Last Post: 21st November 2010, 12:00
  4. Vectra C direct 2.2i fuel pump failure
    By davidu in forum Introduce yourself.
    Last Post: 19th September 2010, 23:58
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
https:www.vectra-c.comforumshowthread.php34006-1-9-CDTI-150-Fuel-pump-failure-help!
vectra c 07 1.9cdti fuel pump
vectra 1.9 cdti fuel tank pump
fuel pump in tank failing 1.9 cdti
1.9cdti fuel tank pump
