Results 1 to 10 of 13
Thread: Climate control not working properly
    Oct 2007
    Australia
    confused Climate control not working properly
    My Vectra's climate control (AC) does not appear to be working properly. When I switch on the climate control the air coming out of the vents is not cold - it is rather warmish (in my old car, not a vectra, the air was cool immediately). I know that a common problem may be that the 'refridgerant level is too low' (according to the technical part of this forum). Any way of checking the level without having to take the car to the doctor?
    Does sounds like it could be a low refrigerant level. Only way to check is using the right equipment - no DIY method really.
    Oct 2007
    Australia
    Smile thanks
    Thanks - I guess i will have to get it checked. It costs about $55p (about $150 aussie dollars) to get the refridgerant topped up and a/c checked/serviced. I spoke to a few mechanics the other day and they said that it was strange that the refridgerant needed topping up since the car is only a couple of years old - but i guess if it wasn't topped up properly to begin with what would one expect. Off to the doctor it goes.
    Jul 2006
    Mexico
    Don`t want to sound sttupid....but is the temp. knob down the blue side (coldest)
    I ask this because time back felt that my A/C was not as cold as it had been...I was about to go to the Stealer and notice that when I cleaned the center console I had moved the knob little bit up(towards the red zone)
    I'm assuming you use the Climate Control all the year round? If not, then the seals can dry up and then cause leaks when it's turned back on again.
    The mechanic should also do a leak test in that service - they inject a dye and you can see any leaks in the system.
    Oct 2007
    Australia
    BlueRob - yeah all knobs are where they are supposed to be.
    Oct 2007
    Australia
    Duncan - yes, the climate control is used (by my wife) pretty much all year round
    Oct 2007
    Australia
    I forgot to mention that there was a bit of fluid coming from under the engine bay the other day when the climate control was being tested around the streets - this happened once the car was parked. I checked the hoses and they appeared to be good. It this supposed to happen?
    That would more than likely have just been water. When the CC/AC removes the moisture from the air in the cabin, it has to go somewhere - and it is discharged from a little pipe under the car. If you sit in one spot with the engine running, and CC on, you'll see a pool of water collect under the car.
    Jul 2006
    Mexico
    Quote Originally Posted by Aussie View Post
    Good! just checking the obvious
  1. Climate control not working properly
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 13:28
  2. climate control panel not working
    By mikeeaston in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:53
  3. OPEL Vectra C - Climate Control Not Working
    By Tigra16V in forum Vectra C / Signum Troubleshooting
    Last Post: 5th June 2011, 22:07
  4. Climate control not working at all
    By cob1980 in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2010, 20:56
  5. Climate control not working
    By steviemac74 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2008, 19:00
