Thread: Wiper Jets
    Regular Member denzo's Avatar
    Runcorn
    Default Wiper Jets
    Frustrating
    One of my screen wiper jets it set too high .... wiper fluid on my roof instead of screen, I alter it a tiny amount and its now too low .... there is no inbetween
    Any advice on resetting these blasted jets ?
    Regular Member suj786's Avatar
    glasgow
    I think you might be able to make slight adjustments by using a needle.
    if you place the needle tip into the nozzle and give it a wee nudge up or down
    Runcorn
    Hi Suj,
    That is what I was trying to use, a fine needle ... no Joy
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Smile
    hi ya another idea is to use is the sharp end of a small nail or the bit that snaps of a small pot rivet seen me using that some times if that helps
    Regular Member barney's Avatar
    nottingham
    I've found that if I insert a needle, pin into the good jet stand back and look at from the side you can see where the pin is pointing then duplicate it with the dodgy jet I found it works, esp if your using two pins you can align them up together.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Trial and error. You have seen that seemingly very small movements cause the water jet to move radically. Keep trying with the needle in the jet.
    Preston Area
    a needle works fine... worked a treat on mine
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    try using a staple gives better adjustment thats what i use
    Regular Member lborob17's Avatar
    Rainy Derbyshire
    Had probs with mine blasting the wiper arms! (since Ive had the car!)- so at the weekend moved them and then they blasted the car behind the car behind me!!
    re-adjusted them yesterday and hey presto they are on my screen!
  1. Problem with wiper jets
    By Kenny_Exclusiv in forum Bodywork & Interior
    Last Post: 8th May 2012, 18:23
  2. Wiper Linkage - failed O/S Wiper
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 15th February 2011, 10:29
  3. Wiper Jets not spraying much
    By mastermaher in forum Troubleshooting
    Last Post: 29th April 2010, 00:25
  4. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
