Thread: Racing Vectra Gearbox....
    spoons
    Guest
    Default Racing Vectra Gearbox....
    This is what I want next
    http://www.tripleeight.co.uk/btcc/transmission.asp
    The transmission, a TOCA standard part, is a brand new 6 speed sequential gearbox manufactured by Xtrac. This is mated to the Vauxhall engine through a racing multi-plate clutch and a bell housing of our own design. To allow us to make the most of the engine power we can change the gear ratios using Xtrac's extensive range so that during every corner the driver can have the engine in the optimum rev range and therefore producing maximum power.
    The ECU, via a sensor on the gear shift lever knows when the driver is going to change up to the next gear and cuts the ignition for a split second, just long enough to allow the gearbox internals to grab the next gear and settle down before full power is returned. By this method the clutch doesn't have to be used to change gear.
    Power is directed to the front wheel through and limited slip differential integrated into the gearbox. The settings of the differential allow us to change the relationship between the wheels and how they rotate relative to each other. This enables us to eliminate wheelspin under acceleration, wheel-locking under braking and to optimise the power and stability of the car.
    Regular Member mickeyc's Avatar
    Over there between the land and the sky!
    Will this car ever end
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    It all sounds good except the racing clutch, BANG, into first, BANG, into second, BANG, ... You get the idea.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    just buy a touring car save all the hasle of building one bit by bit.
    Feb 2006
    Guttedsville
    oops, ignore this one... Admin!!!
    Feb 2006
    Guttedsville
    Quote Originally Posted by nutron View Post
    Not to mention the 'cutting the ignition' to drop the revs for the next upshift, can't see a diesel liking that!
    SOMERSET
    Will it be able to be used in everyday life ??
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Dont know much about this kind of thing, but could this have an adverse effect on the dual mass flywheel thingy?
    Jan 2006
    Hornchurch
    seen a vectra Gsi with a racing box 0 to 120mph was very fast but the top speed was way down over a std box
  1. Anyone got a vectra with bk racing 299s on
    By srinav in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2011, 19:18
  2. DAP-R Racing Springs for Vectra VXR
    By spoons in forum Parts for sale
    Last Post: 18th October 2010, 14:52
  3. vx racing vectra!!!!!!
    By vectrac1988 in forum Styling
    Last Post: 15th June 2010, 12:40
  4. Vectra VX Racing edition?
    By andyxedos in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 15:02
