Thread: fitting rear elec. windows
    Redhill
    Default fitting rear elec. windows
    i have a 56plate sri, was thinking about fitting rear elec windows, anyone done this.. is all the wiring there..???
    any bit i would need apart from the obvious... switches motors new door card
    cheers for your help
    Regular Member Damian's Avatar
    Market Drayton
    Switches
    Looms
    Regulators
    Door card not required as you can fill the hole with a blanking plug, like the ones that cover the screws in the passenger footwell (Trademarked Maverick!!!)
    However I believe there is an issue with the facelifts not having enough pin connections to the rear door, requiring another new loom from the driver door to the passenger door.
    I think Lofty69 had this issue as he has a facelift too, search the forums as I think he has made reference to it and ditched the idea. I have a pre facelift and all that was required was the above list
    Redhill
    cheers, i will have a look... thought it might be a pig of a job...
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Yep, undo the door plug (just push in the blue ring and pull) and check the number of pins at the bottom.. if there's only one you need additional wiring .
    See this thread: http://forum.vectra-c.com/showthread...ectric+windows
    Inverurie
    It's pretty easy to do to be honest. Hardest part for me was trying to get the blasted wind up mechanism out of the hole!!
    Be careful when pulling the door card off, the clips are tight and it really does need some GENTLE pulling/rocking in order to free them. Have done it couple of times now and found it easiest if you pop the one furthest away from the hinges then with the window all the way down, put your fingers in the gap left and rock the panel free.
    Mine was on pre-facelift so it looks like the facelift model doesn't have the loom, but it is worth checking before you go any further.
    The other thing to check before hand is that you have access to someone who knows what they are doing with TECH2 as it'll all need enabling via the onboard computers.
    HTH,
    Andy
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by Damian View Post
    Switches
    Looms
    Regulators
    Double check your info there mate I think you will find the trademark is mine!
    Market Drayton
    Quote Originally Posted by Angel Boy View Post
    Yep, concur with this, my regs were in different positions when I got them, so I had my rear TECH2'ed before I started install, the guy at one of my many dealers knew what to do, obviously the only thing he couldn;t do was test as I hadn't done the install yet.
    There is a little check you can do though, if you have the switch installed in the driver door, when it is selected to rear it will still operate the fronts. Once TECH2'ed it no longer will and the red light on the "de-activate rear windows" button also lights up.
    Quote Originally Posted by leeds vectra View Post
    Many many many apologies
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    I'll see you in court for breach of trademark!
  1. rear elec windows, tech 2 needed
    By Mike1.9CDTI in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2012, 21:07
  2. rear elec windows
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2012, 15:27
  3. rear elec windows
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 18:46
  4. Elec rear windows
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2007, 18:47
  5. What models have Elec rear windows ???
    Last Post: 12th March 2007, 21:57
