Results 1 to 10 of 17
Thread: Spoons Gadget #395749.9
    spoons
    Guest
    Default Spoons Gadget #395749.9
    Right.... time for another gadget !!!
    Whilst browsing the exhibition stands at Clarksons MPH on Friday last week, I came across this little gadget from CG Lock
    Now, I dont normally get that interested in little stands at exhibitions, but this one got me.... and this is the reason....
    Years ago I used to own a car with bucket seats and four point rally harnesses. If you've ever been strapped in a car with rally harnesses you will know how secure you feel, compared to a normal seat belt.
    The problem with rally harnesses, is they look 'chav' and its difficult to fit them with the rear seats still in place.
    What CG Lock have done, is invent a little gadget that turns your existing seatbelts (drivers and passengers) into a 2 point rally harness which effectively allows you to lock your normal seatbelt into place gripping you into your seat. The technology has come from the aerospace sector for pilots harnesses (not that I intent to do a 4G negative dive in my car... but it could happen )
    I fitted them onto the VXRD before the Christmas bash last weekend and gave a demo to some members. I really quite like it and they were relatively easy to fit as well. It can also be used to secure baby seats that use the seatbelt into the back as well..
    Although it is a perminent fixture in the car... it can be disassembled and leave no trace that it was in the car. Just two allen key screws clamp it to your existing seatbelt buckle.... You can pay extra and get an 'instructors' model, which is fully transferable from vehicle to vehicle at a moments notice...
    It will definately get used all the time.
    Very good
    spoons
    Guest
    @ Evo's
    Just read this customer testimonial on their website...
    All I can say is I wish I had thought of it! It stops you having to brace yourself when cornering at speed and means you can concentrate on the track and any hazard that may appear (spinning EVO's). I recommend anyone planning to do any track work with only standard seat belts installed should get one.
    [Ex]Admin Duncan's Avatar
    So basically it keeps the lap belt part of the seat belt taught? - dependent on how you've set the device.
    How does it work in conjunction with seat belt pre-tensioners then? If you've set the device to make the lap belt part quite tight, and you have a crash that activates the seatbelt pre-tensioners, isn't it going to pull the lap belt part somewhat tight on you? - given that it's been tightened already by the device.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I am not sure that I like the idea of fitting attachments to the standard seat belts, one for the reason stated by Duncan (ie being cut in half by the tensioner !) and 2 the seatbelt will no longer behave as designed.
    I would much prefer a full harness installation, even if they look chavy. IMO not too much of a problem for track work, as you prob wouldn't want it for everyday use anyway.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Yep, i can vouch for the gadget. I had a sit in spoons' car with the belt on and it felt really secure, should do the job well.
    When the price comes down, i may get one
    spoons
    Guest
    Quote Originally Posted by Ste View Post
    Yeah, the pretensioners just cut you inhalf Ste.... then whats left of the belt wraps around your neck before impact... slight downside, but hey...
    RTFM
    http://www.cg-lock.co.uk/cg-lock/safety-information/
    Its been extensively tested already... all the magazines are raving about them
    http://www.cg-lock.co.uk/reviews/
    If its installed and you dont want to 'activate' it... you simply remove the slider clip (dead easy) and it allows the belt to operate normally (for use when its fitted to the passenger seat for example).. The main body of the device remains in place but doesnt function without the slider bar...
    Tyneside
    Yeah been looking at these before, but never bought them. Sounds like a good piece of kit, but thos are good points about the pre-tensioners, could have edverse effects.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    These are a good bit of kit.. I got some of these after a mate recommended them to me, Just had a look at the email He sent me and he there is a discount code of BMMC2007 which saved me £20 when i got mine.. I paid £70 for 2 delivered.. Code may still be working, worth a try if anyones thinking of buying...
    Edit:- These are fitted to the Shogun warrior for when we take it green laning or upto Devils pit / Bures 4x4 courses...
    Regular Member wardy's Avatar
    Chichester
    don't think this is anything new. Had something similar on a 1987 mazda 323
    Quote Originally Posted by spoons View Post
    Yep, I understood that - but if you're in a situation (on a track for example) where you've got the device 'activated' and the lap belt part nice and taught, if you suddenly, say, find yourself leaving the track and heading for a crash barrier etc. that you hadn't intended to, the last thing you'll be thinking is "Oh, I must release the seat belt gizmo in case the pre-tensioners kick in"
  1. gadget show
    By neill in forum General Chat
    Last Post: 23rd April 2012, 20:59
  2. Best Gadget...
    By spoons in forum The 'Off Topic' room
    Last Post: 10th June 2010, 11:40
  3. New Gadget from BSR
    By Big-Pete in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 10:02
  4. Gadget show
    By MLC in forum General Chat
    Last Post: 19th May 2008, 21:22
  5. my latest gadget
    By vectra 2.0 t in forum General Chat
    Last Post: 19th February 2006, 21:56
