Thread: Vectra 20DTI problem
    Nov 2007
    Belgrade Serbia
    Default Vectra 20DTI problem
    Hi All,
    My opel vectra c 20 dti have a problem with power loss in mid range. Turn on spanner light, and goes into limp mode everytime i go over 70mph.
    Pull over restart the car, and the spanner light goes out. IF I start off again, get to around 70-80 and it goes into limp mode. as anyone got any idea what it could be?
    In service, check all vacuum hoses, check pressure in intercooler, and evrything is ok?
    Looks like a common failing.
    Greetings,
    Mihailo.
    Mileage : 000
    It might have saved a fault code, if you have a garage that can read them then it might give you some idea, no doubt some one else with the 2.0dti will be able to give you some more help. Mark (gsi3.2) is the man who will be very helpfull.
    Regular Member ulsternush's Avatar
    Oct 2007
    Norn Iron
    Vehicle : 2.0 DTI
    Engine : 2.0
    Check out the below link, it's what sorted my problem.
    http://vectra-c.com/forum/showthread.php?t=32953
    Regular Member tonypc1's Avatar
    on the long road to ruin
    i had exactly the same problem. that link will sort it.
    banff
    i had ther same problem with mine. i took it to the dealer the cleaned a pipe and it was fine, dont ask me what pipe it was an air pipe maybe
    Nov 2007
    Belgrade Serbia
    Default Finally solve the problem which I have past 6 months
    Finally solve the problem. Change diesel injection fuel pump and everything is OK. This part is most expensive part on my car. Costs are about 2200 eur?!
    Thanks for all help on this forum.
    Greetings from Serbia.
    Mihailo
  1. abs vectra 20dti 2001
    By nell1 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2011, 17:28
  2. vectra 20dti can some help, give advice
    By harry71 in forum General Chat
    Last Post: 2nd March 2011, 00:00
  3. vectra 20dti can some help, give advice
    Last Post: 1st March 2011, 23:49
  4. can some help,on vectra 20dti car dosnt start.
    Last Post: 1st March 2011, 23:44
  5. vectra c 20dti non start
    By wunklekex in forum Engine & Drivetrain
    Last Post: 15th January 2008, 10:48
