Thread: Windscreen Interior Condensation
    May 2007
    St Helens
    Default Windscreen Interior Condensation
    I got up this morning to find my windscreen (late 2005 Signum) with ice on both sides! I've never had a car ice up on the insde of the windscreen before. I've noticed the odd time in the last few months in inside of the screen misting up, but not consistently.
    Should I take it back to a dealer, or is there another remedy?
    Andy.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I was getting a bit of misting on my windscreen and after reading a few threads on here, changed my pollen filter as if they get damp they can cause condensation. (definately improved it)
    Although if you have enough to form ice, that might be a leak somewhere.
    May 2007
    St Helens
    Cheers.
    Dont think it's a leak as I've never had any water in, in heavy rain or anything. plus the ice what a flat think layer, probably just the condensation freezing.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    It might help if you close all the air vents before leaving the car overnight.
    May 2007
    St Helens
    Will try that one, they were all open overnight to be honest (including the one on the arm rest which isn't normally open.
    Cheers John.
    Apr 2006
    Quote Originally Posted by AndySkinner View Post
    Cheers.
    Try the pollen filter then mate, only about a tenner from the dealer or you can get them off ebay I think. Only takes 2 mins to fit it as per the HOW TO. HTH
    Full Member Big Sig's Avatar
    Are you 100% sure you don't have a leak? check under the mats, front and back. Excess condensation was what made me look and I had a massive leak coming through the windscreen seal
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    This used to happen in my Astra, stopped when I realised the kids were knocking the door winders when they got in and out the car leaving the rear windows down slightly.
    Also happened in the freelander I had but this was caused by a leaking heater matrix, wasnt ice though just really bad condensation.
  1. Insignia Condensation
    By neverlandandy in forum Insignia car chat
    Last Post: 25th January 2013, 14:11
  2. Creaky Dash/Interior after Windscreen Change
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2011, 21:47
  3. Windscreen Condensation
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2009, 17:38
  4. Clean windscreen (interior)
    By Factory Pilot in forum Detailing and Car Care Discussion
    Last Post: 30th June 2009, 18:11
  5. condensation inner surface of windscreen
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2009, 06:19
