Thread: smell of petrol
    Regular Member kevinmcm19's Avatar
    LUTON
    Default smell of petrol
    hi all
    wondering if you could help when my dad starts the car he is getting a smell of petrol but there no trace of it leaking all so is there any way of getting rid of check safe guard on the radio display
    thanks kevin
    Jul 2006
    Mexico
    For the petrol smell....is the car running fine mate? where is the smell coming from? engine bay or exhaust system? there could be several places to could check....pump, petrol filter, injectors, etc.
    If the smell comes from the exhaust the mix might be to rich which in that case the engine probably will feel some how weired.
    Sorry I can help much....some of the more mechanically minded members will give you more clear hints
    And for the radio SAFE you´ll need to enter the radio code, follow the procedure described on the users manual....the code is written on the car pass...well all of this depends...what radio model does you car have?
    LUTON
    thanks bluerob yes the car runs fine the smell comes from engine bay the check safe guard is nothing to do with the radio as the radio works fine
    Jul 2006
    Mexico
    Quote Originally Posted by kevinmcm19 View Post
    I think itīs better for you to take the car to check that smell....to be on the safe side....no body wantīs to be liking petrol all around the place
    The SafeGuard means that the alarm was triggered, if not, there might be fault on the system or itīs sensors...another Dealer kind of job Iīm afraid.
    LUTON
    thanks
    Regular Member m20_swe's Avatar
    Oct 2006
    greenock
    petrol smell get that in to the dealers mate right away the guy a work with had a petrol smell comming from his feista took it in to the dealers for them to tell him he was a very lucky boy because it could have went up in flames with a spark but there was no sign of a leak before just a smell
    LUTON
    thanks marty dads taking it in on monday hope its not expensive
    LUTON
    dad had it looked at no problems found to do with the petrol smell but the car was very low on oil so the garage changed the oil and filter and the polen filter for some resson
    Oct 2006
    greenock
    always worth checking mate when it come to petrol. is the smell away?
    LUTON
    yes is disapered on Saturday before he took it in typical not a bad price he was only charged £70 for the check over and oil etc
  1. I Smell Petrol
    By Tam80 in forum Engine & Drivetrain
    Last Post: 4th June 2011, 12:54
  2. Smell of petrol in car
    By davidj387 in forum Engine & Drivetrain
    Last Post: 2nd July 2010, 07:46
  3. Petrol Smell
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 5th February 2009, 21:20
  4. Petrol smell
    By cjm4378 in forum Engine & Drivetrain
    Last Post: 24th February 2008, 23:33
  5. petrol smell
    Last Post: 22nd November 2007, 19:40
