Results 1 to 3 of 3
Thread: misfire and belt noise on start up
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default misfire and belt noise on start up
    hi
    i have a 3.2 gsi and just recently when i start it up in the morning it is very juddery and when you rev it it sounds like it is misfiring. also i have a sound which sounds like a belt going round and has a very small squeak also. its hard to described!! i have just had the cam belt done so im worried it could be something to with that?
    hope someone can help
    Full Member Big Sig's Avatar
    More than likely its the serpentine drive belt - the one that does your A/C, alternator etc thats squeeking. Not sure on the rough running. Does it get better when it warms up? Maybe a coil pack on one bank starting to fail
    Feb 2007
    its fine when it gets warmed up. when its cold it judders everytime i change gear and the accelerator does the same when you tounch it. but like i say when its warm its fine apart from the belt noise
  1. CDTI Aux Belt Chirp - When cold or first start only
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 16th December 2012, 23:20
  2. Shocks, Belt and Pump to start with.
    By jonnyrasp in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2012, 15:14
  3. 2.0 Turbo Cold Start Vibrations / Misfire
    By awilson in forum Engine & Drivetrain
    Last Post: 13th December 2011, 11:42
  4. Belt screech on start up/ switch off (2.2.dti)
    By Middo in forum Engine & Drivetrain
    Last Post: 17th September 2009, 11:10
  5. Noisy Aux belt on cold start 2.0T
    By neilbroad in forum Engine & Drivetrain
    Last Post: 27th January 2009, 21:00
