Results 1 to 10 of 21
Thread: DPF...How do I know If I have one?
    Regular Member DeathStar's Avatar
    UP North
    Default DPF...How do I know If I have one?
    Pretty much as the title says....
    Jul 2006
    AFAIK the DPF is only fitted to Signums, estates and autos. So probably not.
    Belfast
    why would it not be fitted to the others? Engine specific component, no?
    Tyneside
    Nope not specific to engines apart from diesels and they're only fitted to siggys, estates and autos.
    spoons
    Guest
    I'm guessing that its due to EC Emissions and regulations for Diesel engines.
    The Signum has the same wheel base as the Vectra Estate, which are both longer than the Vectra Hatch. This means the cars are heavier which produce more emissions. The auto produces more emissions cos its an auto.
    So the Auto Hatchback, Estate and Signum 1.9 CDTi's all have DPF Filters
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by mark1319 View Post
    Actually the 3.0V6 CDTi Manual hatch has a DPF fitted from MY06 onwards.
    Dave
    Chelmsford
    Can't you normally tell by watching for a plume of black smoke when you rev it? Thought DPF were supposed to get rid of this?
    Jul 2006
    Cheshire
    Quote Originally Posted by DNS View Post
    That's right ... DPF cars will not smoke if you rev the car hard while stationary where as a non-DPF car probably will.
    Oct 2007
    estonia
    also you can tell it if your vectra has DPF by differential pressure sensor (a black plastic sensor 1x5cm , 2 rubber hoses (in some cases only 1) come to it + a connector) which I think was located somewhere near diesel fuel filter.
    All diesels will have to have one by 2009 I believe, so it will be coming to the hatch as well, the astra got one when it was facelifted at the begining of the year ..
how do i know if my vectra has a dpf
has my vectra c got a dpf
how can you tell if a vectra c 2007 1.9 cdti has a DPF fitted
