Thread: Coolant Problem
    Feb 2007
    coatbridge
    Default Coolant Problem
    hi,
    over the last 3 weeks the coolant warning light comes on so i have filled the coolant level about 3cm each time. have had a look dont see any leaks but not sure. Any ideas what this could be?
    thanks
    iain
    So are you losing water? you say you keep topping it up?
    Feb 2007
    Nuneaton
    Quote Originally Posted by ilaing View Post
    hi,
    thanks
    iain
    Had the same issue some time ago. In my case it was a water pump seal developed leak. Changed it with cam belt (extra 70 pounds) didn’t top up since for almost a year.
    Regular Member Kyser143's Avatar
    Bradford
    looks like waterpump again...is it making a bit of a noise when running...clicking etc ...mine had some coolant loss was making a noise...ended up needing a new pump
    Feb 2007
    coatbridge
    ok think ive found the problem when i put water in theres alot of it coming back out of this part of the bottle so can i use a sealant to close this up?
    got this image from bluerobs post
    Regular Member DeathStar's Avatar
    UP North
    thats the pressure release.
    Possible a fooked cap.
    if its blowing off too early. does the engine seem to run a little hotter than normal?
    Feb 2007
    coatbridge
    when you pour the water in does some water accidently come out from there cause when i pore it in quite alot comes out of there. Do you think the hole has became bigger somehow?? Perhaps a new bottle?? Had a look under the car dont see any leaks??
    Hmmm it maybe a fooked cap as when the system pressurises its only supposed to vent the excess pressure. Get it sniff tested. Any water in the oil? What happens when you run it up from cold to hot with the cap off?
    Feb 2007
    coatbridge
    ok i booked the vec in to the stealers did a pressure test and seems that the radiator is f****d so they ordered the part hopefully fixed tomorrow. got the wiper linkage fixed under warranty need to see if this will be covered but i doubt it.
  1. coolant problem persists
    By Legion84 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2013, 12:02
  2. signum 3.0v6 elite coolant problem?
    By carmadcarl in forum Engine & Drivetrain
    Last Post: 25th August 2011, 22:57
  3. Coolant Problem
    By MattHD in forum Engine & Drivetrain
    Last Post: 21st June 2011, 13:22
  4. possible coolant problem ?
    By SRI Chris in forum Engine & Drivetrain
    Last Post: 19th July 2009, 19:19
