Thread: camber adjustment
    Regular Member hagga's Avatar
    kingswinford
    Default camber adjustment
    Morning peeps Thinking of getting a coilover setup for the ol' vec as I want to go lower. Has anyone seen any camber adjustment kits for the rear as the vec already has oodles of negitive camber on the back end. Many places doing adjustment bolts for up front but can't find any for the rear.
    Regular Member breezephil's Avatar
    LONDON
    Not Seen any myself, Was thinking of the coilover route myself, but the camber would be a bit much without adjustment kits. Im sure there is one around somewhere.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    I have got Coil Over's on order for mine, they should be here next week.
    Talking to Mark GSi, i am lead to believe that the camber on the Vectra's is adjustable anyway, with or without Coil Over's.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    I had my car put on a laser wheel alignment machine and that said that the front and rear was adjustable, haven't had it done yet on mine as there isn't much point till I put in my new suspension.
    kingswinford
    Quote Originally Posted by BigMan View Post
    thats that then....coilovers it is then
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    the camber on the rear is adjustable but on slightly, not enough to correct the amount of neg camber u get from coilovers.
    ive got coilovers, down as low as they go and have got alot of neg camber. the picture isnt too clear but gives an idea of the camber.
    i ordered a camber correction kit from a place in australia, still got to fit it yet though. basically it replaces the outer bush on the upper arm, and alters the camber with a turn of the bolt.
    Jun 2007
    I think i'll live with the camber and just keep replacing tyres when they need it!
  1. Camber adjustment?
    By Neil07D in forum Handling & Braking
    Last Post: 22nd January 2012, 11:20
  2. Front Camber Adjustment
    By moneypit in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2011, 11:56
  3. Front camber adjustment?
    By Tayla in forum Handling & Braking
    Last Post: 13th November 2010, 14:01
  4. Front camber adjustment?
    Last Post: 11th November 2010, 17:56
  5. Rear Camber Adjustment
    By spoons in forum Handling & Braking
    Last Post: 10th November 2010, 22:00
