Thread: Fixing Sub Grille?
    Jul 2006
    Question Fixing Sub Grille?
    Right...this is kind of embarassing, seeing as I'm usually fairly handy at DIY and electrical stuff....
    This is the grill I've bought to stop the puppy chewing my nice new subs It's honeycomb metal, with a rubber sleeve around the edge.
    Now, the fixing supplied with the grille. There are 4 of these, but no instructions...
    How on earth do I use that to fix the grille to the sub or box? Those teeth DON'T fit into the honeycomb of the grille, before anyone suggests it - I'm not that dumb!
    I just can't see how, once I've got the sub fixed to the box, I can then mount the grille.
    Anyone?
    Feb 2007
    Glasgow
    Kind of like this...
    http://www.harmonsmusicshop.com/prod...oducts_id=1366
    ...Not the best of pictures, but you'll get the idea
    Jul 2006
    Oh, I see. I think. Not very discreet, are they?
    Might have to see what I can do that's a bit less 'bodgit & scarper'
    But thanks
    Regular Member Ben H's Avatar
    Herts\Beds Border
    We used to cut those teeth off as most of the time you'll find the bracket won't sit very well.
    The other alternative was to hot glue the grill straight to the foam surround of the sub and so not using those nasty brackets at all.
    Jul 2006
    Cheers, ben - might do that then. I know there's issues with silicone fumes and sub cones - I presume glue is OK?
    Regular Member Karl's Avatar
    Sunderland
    I just screwed it to my box tbh......
    Took a while to find the right size screw but worked in the end.
    Jul 2006
    The grille is exactly the same size as the sub though - If i did that I'd have to screw through the sub to get to the box.
  1. Air filter fixing
    By keith1983 in forum Petrol Engine related
    Last Post: 16th March 2012, 09:43
  2. Car Mat Fixing clips
    By cap27 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 14:47
  3. Brakes need fixing
    By rob 2.2dti in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2007, 22:00
  4. fixing maybach
    By jacenty in forum Comedy & Humour
    Last Post: 16th February 2006, 00:40
  5. Headlight fixing kit ?????
    By Brake buster in forum Styling
    Last Post: 18th December 2005, 20:59
