Thread: Dualmass replaced...
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    Default Dualmass replaced...
    I have had a seemingly small problem with my car for 2 months now. It was like a missfire, vibration from the engine.
    After doing loads of things to fix it with no results. I finally went for it and replaced the dualmass flywheel.
    Car now runs a dream again. Cost me £330 from Vaux and that included a 25% discount on it.
    My car is a 52 plate 2.2 SRi Z22SE with 56k miles.
    Happy at last.
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Good job mate!
    I've got a very similar car to you (engine and year), just slightly less miles, how long have you had that problem? I keep hearing of people having problems with the dual mass flywheel, but more-so on the diesels? (don't hurt me diesel owners).
    Dave
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    I had the problem for a few months, it got worse in that time too.
    I didnt driven the car much at all in that time though as it just felt wrong!
    They just wear and break down inside, the springs and tensioners die. The fly then becomes loose.
    The new one was tight, the masses could be moved only a few mm each way, whereas the old one was OK one way, but the other way went a good few cm and knocked! Just wear and tear!
    A good way to describe a dualmass fly, is like a normal flywheel with another one stuck to it, but with no teeth. Between them are springs and tensioners that allow them to rotate slightly. This takes up vibration whilst changing gear, etc. Thus giving a smoother ride.
    I have just had a thought, why can these not be 'traded in' like some other parts to be refurbed?
    dudley
    I have had enough of my 07 Vectra and I am going after a Skoda Octavia.
    But get this, the dealer will not touch it with a barge pole and even if he did part chop it, he would sell on to the trade.
    The reputations must be well known.
    Chris
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Quote Originally Posted by CHRISSMART41 View Post
    Chris
    Speak to VV about his Skoda Octavia.
    Regular Member simac's Avatar
    Wirral
    Chris
    Are you mad ? LOL I'd even consider a mondeo before taking that route !
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    Mondeo, ooooooooo, lol, vile!
    dudley
    Quote Originally Posted by SYMON View Post
    Exactly!
    They burn out clutches as well.
    Chris
    Wirral
    Rather have one than an Octavia anyway
  1. What do I need replaced
    By m20_swe in forum Engine & Drivetrain
    Last Post: 25th March 2012, 08:45
  2. Still got my EGR fault... Even with a replaced EGR.
    By cont1204 in forum Engine & Drivetrain
    Last Post: 7th September 2011, 14:25
  3. any one replaced the ecu?
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 23:44
  4. dualmass and clutch vectra 58
    By gazzalad in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2010, 23:45
  5. maf replaced still need help
    By scutster in forum Engine & Drivetrain
    Last Post: 15th May 2010, 10:16
