Thread: Diagnostics/Fault code
    Belfast
    Default Diagnostics/Fault code
    Had a diagnostic check done yesterday at my local indy and the following was noted:
    Glow Plug Circuit B
    Assuming the glow plugs need changed, i went to the factors who informed me that there are no glow plugs available for my car . Its an 04 3.0 V6 cdti. They checked Hella, Bosch, NGK etc. ie all the main m/facturers.
    Can anyone advise what I need to do to get rid of this fault code?
    Jul 2006
    I had my glow plug timing circuit changed under warranty about 6 months ago. Didn't affect the car's running in the slightest cos it was summer. I'd say swallow the bullet and take it to Vx
    Regular Member Sundance's Avatar
    Scotland
    The chances are it will only be one faulty, you will probably find them cheaper than you think at a dealer.
    Belfast
    Quote Originally Posted by Sundance View Post
    I am assuming from your reply my car does indeed have glow plugs?? If so, are they a dealer only replacement? None of the big manufacturers seem to do after market variants.
    I honestly though someone on here could help.
    Belfast
    Is it a difficult job to DIY change the glow plug relay??
    Belfast
    Mods, can this be moved to a more frequented section???
    dudley
    The glow plugs on common rail only come into extended operation when the outside temperature is extremely cold. It should not affect normal engine operation.
    Full Member Big Sig's Avatar
    Yes you do have glow plugs. take it to vx and explain you know what the fault is and ask for a cost to supply/and or fit
    Nov 2007
    lancashire
    had faulty glow plug's on 2.0 dti but was told at a diesel specialist not to bother changing them as they dont even come on till about -8c and wil prob never need them in this country, got to say never had starting probs ect when fuel pump packed in.
    Scotland
    Quote Originally Posted by a18nmk View Post
    yes as already mentioned you do have glow plugs, part number 97357290 RRP of £18.03 + VAT each (maybe a bit more as that is out of a 2006 trade club book)
  1. Diagnostics Fault Reader
    By yates in forum North East RO Vacant - ARO - Vacant
    Last Post: 9th December 2012, 01:02
  2. Diagnostics and Fault Codes readers
    By trickydickySRI in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2012, 02:47
  3. fault code 7e9 a/t
    By mackemade in forum Engine & Drivetrain
    Last Post: 3rd July 2011, 22:28
  4. Code Reader / Diagnostics Scanner
    By r.bailey63 in forum North East RO Vacant - ARO - Vacant
    Last Post: 4th March 2010, 10:34
