Results 1 to 2 of 2
Thread: Signum ABS problems
    Nov 2007
    aylesbury
    Default Signum ABS problems
    Hi chaps, had a hunt around for a thread may have been started already but cant find one so here's my story so far:-
    Bought a 53 plate Signum V6 3ltr diesel last weekend with the abs pump constantly running, even with the key out of the ignition. Now I'm know mechanic but even I thought that the pumps ok, something has to keeping it running like the ECU or relay.
    Had a diagnostic test done on Thurs (not at VX), its brought up 2 codes CO110 and C0121. It appears its the ECU but VX have advised and recommend that if I replace the ECU I must also replace the pump - an independant garage has quoted me 1600 all in of which the parts are 1200!!! They also still have to get VX to do a further diagnostic check just to make sure - should've taken to main dealer first of all!!
    Made some calls today to track down a second hand ECU but to avail.
    Questions-
    Any one know of any good breakers or perhaps I can have them reconditioned?
    Does the pump have to be replaced?
    All help appreciated!!
    Thanks in advance
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    This company was recommended by GSI (if memory serves) as being good. worth a try.
    http://www.autotekelectronics.co.uk/...asterFrame.htm
  1. Signum problems
    By adierolfe in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2013, 19:47
  2. Signum problems
    By Sigchris in forum Vectra C / Signum Troubleshooting
    Last Post: 10th October 2011, 06:54
  3. signum clutch problems
    By dave_3 in forum Engine & Drivetrain
    Last Post: 15th January 2011, 19:41
  4. Signum problems.
    By DHobbs in forum Engine & Drivetrain
    Last Post: 19th April 2010, 19:56
