Thread: 2.0 DTi starting problems
    Central Scotland
    Default 2.0 DTi starting problems
    Morning all.
    I am having a few problems starting the car sometimes. This has only began in the last week or so. Sometimes it will start fine and others it will start then run rough for a few seconds then stall. Then I have to hold the key on for around 10 seconds to get it to start. If I stop and restart after this it is ok. From reading some of the other posts I think this might be the seals on the leak off pipes.
    Does anyone have a photo of the offending items and their locations?
    I would like to get this one fixed before it becomes a major problem.
    Regards
    Ian
    Belfast
    That's an Astra, but same engine. Red star marks the location of the pipe. Once you get the plastic cover off they're pretty obvious (your plastic cover will be different to mine as well).
    Central Scotland
    Thanks for the photo. I had a rough idea but its better getting some real directions before I go playing on my own.
    Ian
    morton
    my wifes refused to start point blank when the leak offs went ! did'nt know that they can start to get worse before not working at all ? the reason hers was'nt starting was the cars ECU detects a pressure loss in the pipes and cuts the fuel off ! but hey you learn summat new everyday !!
    Regular Member rorycarz's Avatar
    Dec 2005
    AYRSHIRE SCOTLAND
    your right itll be your leak off pipes
    May 2006
    Nottingham
    I think there are some little white T plastic adapters on the tubes that can suck air in? I had a problem with my 2.0Dti and I am sure that was the problem.
    Andy
    morton
    ah ! maybe thats the difference !? ours would'nt start and i just changed the leak oof pipes ! if its sruggling to start you need to do both !
  1. 2.0 DTi - Starting problems.
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 01:22
  2. starting problems
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 17th September 2012, 10:03
  3. Starting problems
    By Venom1924 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 23:55
  4. 2.0 dti starting problems
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 11th October 2011, 18:47
  5. problems starting
    By jasoncow in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 23:24
vectra c 2.0dti lumpy start
