Thread: I need some help from our photography circle...
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Question I need some help from our photography circle...
    I have a wad of cash burning me pocket.....And I want some new lenses. You've all seen the kind of shots I take in the galleries.....
    The budget: £1600
    The requirement,
    I'm gonna get the Canon 100-400 L series lens (£900 from a reputable shop or £785 off Ebay)
    I want a good general purpose (Canon) lense that fill the gap from 17-100 as best as possible so I can ditch the naff 17-55 and 90-300 lenses I have.
    I was thinking of the EF 17-85 IS for £300 then found the EF 24-105 L series lens for £600 but I do go down to 17mm regularly.......
    Any ideas? My Head hurts right now and the photography forums I use aint much help!
    Mileage : 000
    I don,t know if they do a lens like I use on my Nikon it is an 18 to 200, I find it very very useful, perhaps the most useful size of lens I have had on a camera.
    Feb 2006
    Wirral
    There's a 28-300 for £1600
    there was a 35-350 but thats not around any more!
    Is IS something that you want? (for the longer focal length), or not fussed?
    Feb 2006
    Wirral
    Prefered mate...I seam to get alot of fuzzy shots even when i'm using some sort of support. Tripods,walls etc
    Feb 2006
    Dorset
    Ive got a Panasonic Lumix DMC FZ8 and thats enough for me , ive switched on the shake thing and ... err thats about it !
    Nicking Ya Dinner.
    Looks like someones fed up with fixing ships and is eying up the position of Vec C ,Chief Photographer in the near future.
    Regular Member breezephil's Avatar
    LONDON
    Brocks what camera are you using??
    Im assuming with the 17-55 mentioned its something like a 350D/400D or 20D
    What you have to watch is a 17-55 EF-S is the Equivalent to 17mm on a Full Frame Camera, the above have what is known as a cropped sensor (x1.6) - so 17mm on an EF Lens - i.e. the 17-40mm would equate to 27-64mm
    If that made Sense. I've made that Mistake before - thought it was a wide angle that didn't turn out so wide. Now I'm on Full Frame Digital it is how it should be.
  1. Quick Q? Dash warning light orange circle in brackets?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2009, 15:20
  2. Problem..theres a sign on my dash..circle with 3 lines on each side..?
    By vec3.2 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2009, 11:29
  3. Ignition Circle Light
    By CristianTM in forum Styling
    Last Post: 17th April 2009, 06:50
  4. Circle Flies
    By Tadpole in forum Comedy & Humour
    Last Post: 20th January 2009, 01:38
  5. Car Photography
    By VXR_DV in forum General Chat
    Last Post: 25th October 2008, 10:38
