Results 1 to 10 of 18
Thread: Centre Screen Brightness
    Regular Member DeathStar's Avatar
    UP North
    Default Centre Screen Brightness
    You chaps will have the answer to this
    I have just upgraded/downgraded from a Design to a SRI.
    The problem I have is that the screen is a bit bright, I have the CD30 in this and the 40 is the design, which you could invert and alter the brightness.
    Is this possible on the SRI with the CD30?
    thanks in advance
    Mileage : 000
    Never really noticed on mine but if you have one of the Four bottons on thr light switch that adjusts the dash lights that might dim the screen as well, as I say I have not noticed if mine has dimmed when I have adjusted the dash lights.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    IIRC its done with the dash dimmer switch which like Ed says above is part of the headlight switch. HTH
    Feb 2006
    Dorset
    the sri screen is not switchable from neg to pos like the design , only real way you could dim it is a dab of tip ex on the led's and that means pulling the display apart , i find the sodding sidlight indication light and main beam light are too bright at night .
    UP North
    Yeah, that's another thing I have noticed...the dash lights are always on. So you think you have your lights on when you don't. Luckily I have not been caught out yet. But as dusk it could be a issue.
    I assume when you say pull the display apart. You mean remove the trim and remove the screen wioth the vents, then hoyk the screen out?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I can adjust mine in the settings. You can have it on NEG, Poss or auto and then you can adjust the brightness.
    VOTING UKIP IN AVELEY
    5 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    erm i can dim my screen on the sri...........go into settings and switch from night to day mode
    Feb 2006
    Dorset
    Depends on the year rushy , if its a new one it will have the 3 line display which you can read from 100 miles away ...
    deathstar ,
    yep its a remove the screen and take it apart , ive done the tip ex thing a couple of times on pioneer stereos for mates , they are very distracting at night , its a bit trial and error but it works .
    Vehicle : SRi
    Mileage : 137000
    2005 HU on mine,
    5 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    guess weve got old cars then Rushy lol
  1. Centre Screen
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2012, 17:09
  2. Problem with centre screen
    By ScotsDragon in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 20:27
  3. centre screen layout
    By mat100edt in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 10:29
  4. Centre screen out :0(
    By big O in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2007, 18:18
vauxhall insignia screen brightness
vauxhall insignia display brightness
opel vectra lcd brightness
