Results 1 to 10 of 22
Thread: Cam Belt Change Intervals
    Regular Member denzo's Avatar
    Runcorn
    Default Cam Belt Change Intervals
    Hi
    Can someone post the cambelt intervals for 1.8i Petrol and 1.9 CDTi (Z19DTH)
    I thought the Z19DTH = 100,000 miles or 10 years
    How long will you go before getting it replaced though?
    Denzo,
    I'd be a brave man to leave any belt to that mileage..Remember when VX extended the change interval to 80K. Warranty claims were thick and fast..
    I wouldn't leave a belt on my car past 36K..If you change it yourself SEALEY do a locking kit for the pulleys etc for £90.00
    Runcorn
    Vx told me that the CDTi was 100,000 miles or 10 years .... I was suprised
    WOW!!
    I'd be having kittens by 50K..
    Darlington
    Got the Annual inspection sheet from VX in front of me
    no mention of a toothed belt on the 1.9 diesel! must be a chain
    MY 2001 UPTO MY 2002 Z18XE,Z18XEL EVERY 4 YEARS/40000 MILES
    MY 2003 Z18XE EVERY 6 YEARS/60000 MILES
    Regular Member Basil's Avatar
    Nottingham
    Quote Originally Posted by MadamVectra
    You are totally right, the 1.9 cdti has a chain as opposed to a belt that just requires periodical checks, although after a while it will need links taking out to keep in the correct tension range as it stretches with age/use.
    I didn't realise the 1.9cdti was a chain, is that the 8 & 16 valve engines?
    Regular Member ion's Avatar
    walsall
    I thought it was a belt also. Are you certain it's a chain?
    If so I hope it doesn't suffer the blocked oilways problem that the b had. A few engines were shafted by that.
    just done 30k in my 1800LS ,just had it changed with the idler as well.VX charged £151.00 all in ,but still under warranty so nothing to pay..
    Should have been changed @ 40k in service manuel.
    Leicester
    1.9 CDTi is 100,000 or 10 years, I am at 52500 miles now. Not bothered though, it if goes before 100,000 miles then vauxhall get the bill. Simple as that.
    I checked with trading standards about this, they stated that if Vauxhall state 10 years or 100,000 miles then they are guaranteeing it will be OK during this time.
  1. 2.0t timing belt intervals.....
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2012, 02:12
  2. V6 Cam Belt Intervals
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2009, 17:23
  3. Cam Belt intervals VXR?
    By mradz in forum Engine & Drivetrain
    Last Post: 26th May 2009, 08:32
  4. Service intervals and cam belt change???
    By thompo5 in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 23:56
  5. timig belt intervals
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2008, 22:33
