Results 1 to 10 of 17
Thread: tyres
    Regular Member kns's Avatar
    Northampton
    Default tyres
    Hi All,
    I am looking at replacing my 215/50 r 17 Nct 5 tyres for 4 x Goodyear Eagle F1 GSD3 225/45 R17 Y whats your thoughts on these tyres as my local fitters say i would need to change all 4 as i am going to a wider tyre is this right?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    no.
    You only have to match tyre sizes per axle.
    The tyre place is wrong, according to MOT, construction and use, homologation, road traffic act etc etc
    Northampton
    Engine : A20DTH
    Mileage : 88000
    you will be dropping the diameter of the wheel with the new tyres. I am sure this has an effect on the speedo and speed in general
    Regular Member Dodger's Avatar
    West Midlands
    Quote Originally Posted by kns View Post
    Hi All,
    I pretty sure you can get away with a pair on either axle, but check.
    Just replaced mine nice got a good deal me thinks £320 for 4 fitted and balanced with shiny valves
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Quote Originally Posted by merikiito View Post
    Not enough to make a difference,also put the wider new tyres on the rear,won't look daft also the best place for them for handling.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    ?? don't understand.
    The wheel size are the same at 17".
    The rolling circumference with change by about 2% = = OK
    As long as the tyres on the same axle are the same size, that is OK for the law.
    Speedo out by 2% is not worth worrying about, tyre tread change can be nearly this as the tyre wears out.
    Regular Member wardy's Avatar
    Chichester
    Agree with Ste.
    I did exactly this, put 2 new 225/45 on rear & put old 215/50s on the front until worn out. Some cars come with wider tyres on the rear as standard, so the fitter is talking out of his AR55
    Belfast
    If the tyre place is giving that advice, walk away and find one that knows what they're talking about.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    most tyre centres will try to sell 4 new tyres more profit in the till
    Considering the speedo is not correct to start with, 2% or so make NO difference at all. It would also read slower not faster so its a bit safer with the speeding laws.
    Quote Originally Posted by Ste View Post
    Totally agree
  3. More tyres....!
