Results 1 to 10 of 30
Thread: Washing machine inlet valve
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Washing machine inlet valve
    any suggestions on the best way to test the inlet valves on my washing machine???
    cheers guys
    Russ
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Turn on the water and stand back?.......or am I missing something here. They either work properly or not
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by john_k_sri View Post
    they are electrically operated solenoid valves, i need to figure out which one is knackered so i can replace it.
    any ideas?
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Can you not turn off each feed in turn to see which one fills and which one doesn't?
    Here, there and every where!
    Is it hot and cold fill, are they single or double solenoid valves?
    Short of taking each inlet pipe off in turn and operating each programme it is very difficult to pinpoint which one is not opening.
    You can test the coils with a meter to see if they are ok, the same goes for the electrical supplies to each of them but again you will have to run through each programme. The machine uses different valves depending on whether you are on a pre-wash, rinse etc.........HTH
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it the coil or the solenoid valve internals?
    A simple continuity check of each coil will test those, using a multi meter (obviously you need to disconnect them aswell)
    EDIT :
    Beaten to it..... by a mod aswell
    Mar 2007
    Grimsby, Lincs.
    it has a single hot valve, and a double cold valve, i suppose i could do a continuity check on each coil to make sure the loop is there
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The coils just unclip and are dead easy to replace.
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by Ste View Post
    ahhh how much are the coils tho..... lol
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Not a lot, any decent plumbers merchant will stock them, just take the old one in with you.
    Disclaimer :- The 'easily unclipped' comment relates to general washer solenoid valves and not complex, stupid, integrated or any other types that are not 'easily unclipped'
  1. broken washing machine
    By john norris in forum General Chat
    Last Post: 22nd December 2012, 16:25
  2. phone v washing machine
    By beat275 in forum The 'Off Topic' room
    Last Post: 20th November 2012, 16:50
  3. Broken Washing Machine
    By John Bishop in forum Comedy & Humour
    Last Post: 14th June 2012, 16:56
  4. Any washing machine engineers on here?
    By MrsJR in forum The 'Off Topic' room
    Last Post: 4th May 2009, 17:12
  5. Washing machine
    By LOCKSTOCK in forum General Chat
    Last Post: 2nd February 2009, 05:24
